Help me please 72 Ford F100 bleeding brake
Please look at pictures i posted
Ok, I can not get socket or wrench inside the space between the knuckle and fitting. I am about to push this ford off a cliff... i don't understand how come they made it so hard to get to... one little fitting...
Please look at my pictures to see what I am dealing with....
http://www.fatboyspigpen.com/images/DSC01267.JPG
http://www.fatboyspigpen.com/images/DSC01264.JPG
http://www.fatboyspigpen.com/images/DSC01265.JPG
http://www.fatboyspigpen.com/images/DSC01261.JPG
There just isnt enuff room to get a socket with the rachtet on it and no wrench fits in there that I have....
I really need to get this thing bled tonite... thanks for any help....
If all you did was change the master cylinder than you can get someone to pump the brake a few times and hold it then you can crack the brake line loose and it will bleeded. If your brakes still feel odd chances are that you brakes need to be adjusted. My 69 did that I put a new master on it and then I had to adjust the brakes to make it feel right. I hope this helps.
What I usually use in tight spots is a short 1/4" drive socket, 1/4" UJ, on a 1/4" extension. If you turn the wheels, this looks like it would fit, no problem. From the looks of that line and fitting, I would hit it with PB Blaster and clean out the nipple.
bigcountry1009
05-13-2009 12:09 PM
john smith jr
08-29-2008 06:56 AM
G Guess
07-15-2005 11:23 PM
