Glow plug amp draw
Old May 17, 2011 | 12:09 PM
guitarpicr's Avatar
guitarpicr
Glow plug amp draw
Does anybody know the amp draw for all 8 glow plugs, or approximately what it should be?
Old May 17, 2011 | 12:10 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
It depends on how long they've been on.
The longer they're on (the hotter they are), the less current they draw.
Old May 17, 2011 | 12:30 PM
guitarpicr's Avatar
guitarpicr
Ok- I was thinking I could tell roughly if all 8 were working without ohming out the connector. Pretty sure a couple of mine are bad. Probly just change them all out one of these days.Thanks, Bill
Old May 17, 2011 | 12:41 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Unfortunately, I've been burned once while just "ohming them out". They had good continuity when cold, but as soon as they were warm, they'd go open and not work at all.
Old May 17, 2011 | 01:01 PM
Nick 99's Avatar
Nick 99
I remember someone doing a current test, but I can't find what they measured. Stay tuned, someone will come up with the right current reading.
Nick
Old May 20, 2011 | 12:28 AM
White 99's Avatar
White 99
I have seen about 50 or a little more on each side using the AE. I think my clamp on amp meter showed a little less maybe 40 something each side. I could check again to make sure if you want.
Old May 20, 2011 | 07:25 AM
bfife's Avatar
bfife
still plays with trucks
on a cold engine they should peak at 188-192 amps then drop down from there.
Barney
Old May 20, 2011 | 07:59 AM
Izzy351's Avatar
Izzy351
If you average them at 1 ohm in parallel, you're looking at Current (I) = Voltage (V) / Resistance (R). At 12 volts assuming 1/8 ohm (1 ohm / 8 GPs), that's 96 A... As resistance goes down, current goes up. If some of the GPs are less than 1 ohm (let's say, total load goes to .1 ohm instead of .125), current goes up to 120A. To get 200A, you'd need them all to be about 1/2 ohm each for a total load of about .06 ohms. 12V/.06 ohms = 200A.
Y2KW57
59
Jan 29, 2017 01:44 PM
nelstomlinson
Apr 18, 2016 11:41 PM
Sparky50
Mar 8, 2016 10:45 AM
Firefighter 1406
Oct 31, 2011 07:28 PM
havns3
Dec 17, 2010 06:14 PM
