instrument cluster removal
Old May 17, 2011 | 09:37 AM
jayrus544's Avatar
jayrus544
Has anyone removed the instrument cluster tor replace one of the bulbs? I guess they have bulbs don't they? How big of a pain is it?
Old May 17, 2011 | 09:35 PM
Fox Fader's Avatar
Fox Fader
I've done many, but not on the 150. The mostly are pretty simple to do, just be careful and take your time.
Old May 18, 2011 | 08:06 PM
Joe04F150's Avatar
Joe04F150
very easy to do, just make sure to disconnect the battery prior to pulling them out and only connect it after reinstalling them
Old May 20, 2011 | 08:07 AM
hcbph's Avatar
hcbph
Bulbs
I had a 79 & 84 Cutlas that had the same issue: remove the dash to replace the bulbs. Started removing the plastic lense over the speedometer assembly and turned out I could see the burnt out bulbs but couldn't reach them. I have not had a F150 dash apart so I don't know if this might work but seems like it's worth a look.
I took a pair of hemostats (like a doctor uses), I wrapped the gripping end with masking tape, sticky side out, then alittle more higher up to stick that to the hemostat. I was able to work it around the edge of the speedometer and grasp the end of the bulb and pull it straight out (this had the bulbs that push into a plastic cap, then the cap twists into a hole in the back of the dash). Replacing the bulb was simply the reverse.
I had to change about 5 or 6 in the pair of Cutlas's I owned, and after the first time, I got it down to about 10-15 minutes per job.
I wish the designer that decided you have to pull a dash to change a burnt out bulb was relegated to doing that for a year or two, I'm sure there'd be some dramatic changes in the future.
Hope it helps.
landers0440
Jun 24, 2014 10:43 AM
85AustinTucker
Nov 4, 2013 07:48 PM
LARIAT 85
Aug 15, 2012 06:20 PM
neufelda
1983 - 2012 Ranger & B-Series
Mar 31, 2004 08:21 AM
Kevin
Jan 4, 2000 12:19 PM
