Which coolant
Old May 18, 2011 | 12:19 AM
steelhead2's Avatar
steelhead2
Originally Posted by flamebuster
EGR valve? Won't that get water in the intake and turbo? Or did you mean the remove the thermostat?
sorry....I meant the egr cooler.
Old May 18, 2011 | 12:25 AM
steelhead2's Avatar
steelhead2
Originally Posted by ilcowman
So just to make sure that im 100 percent understanding after draining my system pull the cover off the top of my oil cooler and shoot some hot water the hole and try to wash that crap out also got a quart of vc9 today but the guy at the dealer said to only use 4-6 ounces is that correct
make sure you got a good seal around the hole before giving it water pressure,if you don't you'll get wet.and use the vc9 after you backflush the cooler,then backflush it after the vc9 treatment until it comes out clean.I took the left side block plug out and left my bottom radiatoe hose off when I did mine.and use the full quart on it.after all the backflushing you'll still need to flush the system to,I just filled it normally,got it hot,and pulled the lower radiator hose off.and repeat that about a dozen times until clean.
Old May 18, 2011 | 08:28 AM
ilcowman's Avatar
ilcowman
So drain the system then backflush the cooler then fill back up the system a put the vc9 in I will have the thermostat removed how long should I leave the vc9 in
Old May 18, 2011 | 08:44 AM
flamebuster's Avatar
flamebuster
I believe the bottle says 20 min. but you will see better results if go drive around for at least an hour..
Old May 18, 2011 | 01:26 PM
ilcowman's Avatar
ilcowman
The bottle I got has no directions on it how nice
Old May 18, 2011 | 01:41 PM
steelhead2's Avatar
steelhead2
https://www.ford-trucks.com/forums/p...ictureid=70423
Old May 18, 2011 | 01:58 PM
steelhead2's Avatar
steelhead2
https://www.ford-trucks.com/forums/p...ictureid=70424
Old May 18, 2011 | 01:59 PM
steelhead2's Avatar
steelhead2
sorry for the round about way of posting pics.i couldnt figure out how to add them right to the thread in one shot.
Old May 18, 2011 | 02:46 PM
ilcowman's Avatar
ilcowman
Whats the extra valve for
Old May 18, 2011 | 06:49 PM
steelhead2's Avatar
steelhead2
For adding restore.id put about a cup in between water blasts.
Old May 18, 2011 | 08:39 PM
ilcowman's Avatar
ilcowman
Is bpd the only manufactur of the oil cooler that goes on the radiator and delete the stock one
dventoza
Feb 9, 2011 12:13 PM
mufflerbearing
20
Apr 23, 2010 05:54 PM
pcsurgeons
16
Sep 26, 2007 01:30 PM
tired-n-dusty
Aug 30, 2005 10:08 PM
01' Super Crew
1997 - 2003 F150
Mar 6, 2003 09:26 PM
