Im getting ready to do a coolant flush which coolant should I put back in also is there an online site where I can order restore cant seem to find it anywhere
Dont put any in until you verify your ect vs eot.if its good then put red elc back in.also,in your last post you were about 15* apart.try back flushing your oil cooler.I was 27* apart,after the back flush I'm at 18-21* apart.not ideal,but it obviously helped.figured Id give it one more try today and got it down to 18* at 60mph,but at 70 it climbs to 18-21*.ill give the vc9 a try and backflush one more time and see what happens.good luck to ya,hope you can get those temps down.
Yea I was going to backflush my oil cooler but the only access I have to this forum is my cell phone and the link I got I could find the directions it told that it did good but I couldnt find the steps to do it
Pull off the cover to the egr valve.its by the turbo outlet pipe.its got two torx screws holding it down.I made up a deal with a half inch ball valve,a standard garden hose adapter on one end,a three foot piece of garden hose with a barbed fitting inside another adapter.the fitting is sticking out of the end of it and I found a piece of rubber,actually it was an aftercooler bushing with a.hole in it,and put it on the barbed fitting,held it tight in the exposed hole of the oil cooler and pulsed water through it with the ball valve.ill try to post a pic of it.when you put the cover back on go get two allen head screws and a long allen wrench,put a fourty five bend in the long end,much easier to deal with then those damn torx bolts.
EGR valve? Won't that get water in the intake and turbo? Or did you mean the remove the thermostat?
So just to make sure that im 100 percent understanding after draining my system pull the cover off the top of my oil cooler and shoot some hot water the hole and try to wash that crap out also got a quart of vc9 today but the guy at the dealer said to only use 4-6 ounces is that correct
Wow, nothing like pictures, I never would have thought of trying that, but now I am going to give it a try. Any improvement is worth it to me. Thanks guys.
Yes it is but it must be concentrate not the 50/50 mix stuff some guys have said that Cat only has the 50/50 stuff that will NOT work. Any ELC coolant that is CAT EC-1 Rated coolant will work.
