6.9L Fuel pump mod
Old May 16, 2011 | 08:46 PM
Fratzog440's Avatar
Fratzog440
6.9L Fuel pump mod
Ok so I've been thinking about turning up the injector pump a little on my 6.9, just 1/6 turn max, but I won't be able to get a Pyrometer for about 2 weeks-1 month. Will I be ok for a little while if I drive it nicely or am I going to blow up my truck right away?
Old May 16, 2011 | 09:47 PM
ctubutis's Avatar
ctubutis
Probably not right away, no.
But, why do you want to do this?
Old May 16, 2011 | 10:04 PM
Sw1tchfoot's Avatar
Sw1tchfoot
I read that without a turbo the EGT's will go up faster as you turn up the fuel than if you had a turbo.
Old May 16, 2011 | 10:09 PM
Fratzog440's Avatar
Fratzog440
Well i've heard it adds a little bit of power and I know it adds a little bit of coal. And someone will get mad at me for this, but where I come from, everybody drives a diesel and smoke is considered "cool". And cops don't care. Cuz my 6.9 with a little black isn't as bad as the idiot with the 30 foot tall cummins a block away with a 250 HP chip in it.
Old May 16, 2011 | 10:12 PM
Fratzog440's Avatar
Fratzog440
Ya and its a $500 truck so i dont wanna put a $2500 turbo on it. just a little free mod. and i am getting a pyrometer, im just in the middle of nowhere for the next couple weeks so i wont be able to get one till i get home. and i wanted to make sure its safe
Old May 16, 2011 | 10:23 PM
84-6.9L's Avatar
84-6.9L
If you want to be comletely safe just wait til you get the pyro. It takes just 10min to turn it up so why rush it. And yes on an NA motor egt's will rise very quickly.There is no way to tell if it has already been turned up a flat of so and when you turn it up another on top of that your pistons will get hotter then the sun.
Old May 16, 2011 | 10:31 PM
Fratzog440's Avatar
Fratzog440
I bought it from a friend of mine's grandpa and he said they hadn't done anything to it. it has 422,000 km on it and still runs like a dream. so it has been well taken care of. Ya i'll maybe wait till i get the pyro. depends how bored i get. do you guys know of any other cheap little mods on these engines?
Old May 16, 2011 | 10:51 PM
84-6.9L's Avatar
84-6.9L
Cut your soup bowl out of the air ceaner and fix up a ram air intake. Hop over to the idi forum theres a bucket and a half of info on these old beasts
Old May 16, 2011 | 10:54 PM
Fratzog440's Avatar
Fratzog440
Ok thanks. I didn't know there was a separate forum for IDIs, i just saw 80-86 and figured it was the right one
Tom's Avatar
Tom
That's cool, huh? How cool is it to be stuck on the side of the road with a junked truck with burnt pistons? How cool is it to have to buy another vehicle because you wrecked the engine in your current one?
I was riding with a guy with a tuned truck when he melted his down while towing my trailer up a hill. Had to get towed 40 miles to the shop. One month and $7,000 later he was back on the road. He did not look or feel cool at that point.
I'm willing to bet I'm not much older than you, and believe me there are many more important things to worry about than looking cool. Things like keeping that truck running as long as possible, being able to afford to go out with friends instead of fixing your truck, etc.
Why risk your truck over something like this?
Old May 16, 2011 | 11:11 PM
Fratzog440's Avatar
Fratzog440
I think you missed the part where i said turn it up a little bit. not crank it all the way. and the point of this whole thread is seeing if it is safe to do. I'm not going to do anything that will destroy my engine. I have seen guys melt engines. By not having a pyro or ignoring it and running at 1700 Degrees. I'm not an idiot. Just wanna add a little bit. i'm getting a pyro and will keep it under 1200 at all times. From what i've read. this adjustment is relatively safe up to half a turn on the pump. three times what i'm planning.
Old May 16, 2011 | 11:39 PM
84-6.9L's Avatar
84-6.9L
And don't worry your old truck will give you plenty of this to try and fix.(don't ask me how i know) I always carry a wrench set a few screw drivers and a vise-grip. There's never been anything a can't fix good enough to get home.
Old May 17, 2011 | 07:05 AM
Tom's Avatar
Tom
I get what you're saying, but remember that more fuel will equal much higher EGTs, no matter how much you turn it up.
The truck has over 400,000 KMs on it, meaning that engine has seen a lot of use. At this point there's not much that can't go wrong with the truck, and if this is your primary vehicle you are probably best suited to doing what's best for the truck.
I've never seen a "safe" engine mod, as you change the way the engine operates from what it was designed to do.
It's your truck, and I hope you do what makes you happy. I hope I'm wrong and it lasts a long time. Good luck !
Old May 17, 2011 | 08:05 AM
fellro86's Avatar
fellro86
I have mine turned up a little, but the max I see for smoke is a light haze, that way i can be more comfortable that it isn't getting too hot. I know i need to add a pyro, but I am confident it isn't so hot when there isn't too much excessive fuel. Besides, I don't want to see excessive black rolling out, I can't afford to waste fuel that way. I need reliability and efficiency. I don't want black smoke. Its cool at the pulls, but not on the street.
72f2504x4390
19
Mar 23, 2018 02:09 AM
diesellife85
Mar 1, 2016 10:04 PM
MrCat4974
Nov 10, 2014 10:06 PM
natedowney
15
Sep 29, 2014 11:36 PM
540milotalon
Jun 2, 2014 07:11 PM
