Sponsored by: Auxito
Trailer HELP
Old May 16, 2011 | 07:06 PM
Mtntraveler's Avatar
Mtntraveler
Unhappy Trailer HELP
i have a 1997 F-250 the 7700 package model 5.4 Triton 6800 GVWR and ive been pulling my 2000 28ft 5th wheel 6000 Lb travel trailer around local but iam thinking about a cross country trip iam wondering if i should upgrade my truck first?
Old May 16, 2011 | 07:18 PM
BadgerBoy's Avatar
BadgerBoy
Originally Posted by Mtntraveler
i have a 1997 F-250 the 7700 package model 5.4 Triton 6800 GVWR and ive been pulling my 2000 28ft 5th wheel 6000 Lb travel trailer around local but i am thinking about a cross country trip i am wondering if i should upgrade my truck first?
You should be okay with 6000lbs. You won't be flying up the steeper grades with it though but it will do it. What condition is the truck in? Also what is your gear ratio?
I pulled a 36ft fifth wheel which weighed around 9,000lbs empty with my f250 light duty just like yours when I had it, the only thing I lacked was power but you will be significantly lighter though. Eventually I did upgrade to a 08 super duty but 3,000lbs is a big difference, I had a travel trailer before that was almost exactly the same weight and it pulled it fine. I loved my F250 light duty.
Also if you have the 7700 package that should be your GVWR which is amazing for any truck at the time. The payload rating was up to 2850lbs, not bad for what was classified as a half-ton truck. One thing is for certain, that truck will ride really nice going down the road; mine always felt like a Cadillac when it had a good size load on it.
Its also rated to 8000lbs for a fifth wheel I believe. I would at least never go over that just because the 5.4 can't really pull anything heavier than that, the suspension is the best part on that truck and the only thing that did truly limit its capabilities was the engine.
Old May 16, 2011 | 07:42 PM
Mtntraveler
Thanks BadgerBoy
My truck is in Great shape except age and some rust but engine an Trans all work good
Old May 16, 2011 | 07:51 PM
BadgerBoy's Avatar
BadgerBoy
I would say you should be fine, my father and I pulled just about everything we could hook up to it. It did everything for us, the only reason why we got rid of it was because we upgraded to that 36ft fifth wheel and it crawled up the hills. Even with that amount of weight the suspension and the rest of the truck handled it great.
Old May 18, 2011 | 01:52 AM
Bear 45/70's Avatar
Bear 45/70
DO NOT TOW IN OVERDRIVE!
tatonka
Nov 22, 2013 04:34 PM
bigbadassfords
Aug 17, 2011 11:33 PM
new2fordf250
25
Dec 26, 2009 11:56 PM
ranger56528
All Things Towing
42
Nov 21, 2008 01:46 PM
redneck1877
Aftermarket Products
Aug 5, 2004 06:37 PM
