P1211
Old May 16, 2011 | 08:13 AM
UncleShank's Avatar
UncleShank
P1211
I wanted to see if my truck was throwing a code since I installed a new exhaust system Saturday. My bully dog triple dog GT has a diagnostics section and it says it's throwing a P1211. I think I've seen this before and think it's an over boost code. Anyone know?
Truck is a 2001 7.3 w/ 151k miles. One in sig
Old May 16, 2011 | 09:21 PM
dwright5460's Avatar
dwright5460
ICP not controllable, pressure above/below desired, this is per Mitchell on demand, hope this helps
Old May 16, 2011 | 09:25 PM
Izzy351's Avatar
Izzy351
Common on trucks running tunes. It means your HPOP can't keep up with the demand from the (VERY oil hungry) stock injectors. I was setting that code all the time until I went with hybrids. No longer an issue and I'm holding 2800+ psi now.
Old May 17, 2011 | 06:21 AM
UncleShank's Avatar
UncleShank
What can I do to get rid of the code for good, without replacing my injectors?
Old May 17, 2011 | 07:28 AM
Kwikkordead's Avatar
Kwikkordead
Big oil, otherwise known as dual HPOPs.
Old May 17, 2011 | 08:29 AM
bfife's Avatar
bfife
still plays with trucks
1211 code is normally because the tuner is keeping the injector open too long.
properly written tunes WILL NOT set this code. but that requires tunes written by a custom tuners, not over the counter tunes. Power Hungry, Tony Wildman, Gearhead, DP tuner are just a few.
Plugged fuel filters will cause this also. But you will notice a big drivabilty issue if its lack of fuel
You can install an ungraded HPOP like an Adrenaline from Dieselsite, or upgrades from Terminator or Riffraff
Barney
Old Jul 14, 2012 | 11:17 AM
Wizdom's Avatar
Wizdom
Help p1211
I have a new ICP n IPR N high pressure oil pump n injector I had the Service Engine light come on the other day and found a p1211 error with no pending codes. I have did evey thing help me or just call6192478959
Tailgate77478
Jun 3, 2017 07:06 AM
bcarless
Mar 5, 2016 08:25 PM
lstitt
Australia Chapter
Dec 22, 2015 02:43 AM
sudsmcduff
Nov 14, 2015 06:10 PM
bcarless
Nov 9, 2015 05:35 AM
