hello all, cant seem to find my answer anywhere but can i buy stage 1 injectors with out a programmer on my truck in signature. im debating getting just remans or stage 1's. also i was woundering if you all sugguset changing injector cups and glow plugs and what about the wiring harness and gaskets? i want to do it once done and right.
this is something im planning on doing in the early fall and want to get everything but injectors boughten if i need it.
I'm not an injector expert but you can use stage 1 but it has to be splitshots as for the rest of your questions,how many miles on your truck.It would be nice to change all of that since your in there but i did mine with only 80,000 miles so i just left it in there.
"True" stage 1 injectors will require custom tuning to run properly. Edit: Don't waste your time staying with split-shot injectors. If you're going to do anything with the injectors, get singles.
Edit: You should invest in a least an EGT gauge because the stage 1s may very well cause higher exhaust temps when you put your foot into it or when towing.
