Intercooler with stage 1's????
Old May 12, 2008 | 02:10 PM
matt71's Avatar
matt71
Im getting ready to get the DIY stage 1 rebuild done. Will I need a intercooler with these injectors. And will my stock HPOP handle these?
Old May 12, 2008 | 02:15 PM
secondarychaos's Avatar
secondarychaos
Stock HPOP is fine- With DIY stage 1's you changed the plunger, but not the intensifier piston. What this means is you got more fuel at a lower pressure, for the same amount of high pressure oil.
An intercooler will benefit at any power level, and that would help your EGT's some, but with 1's and supporting mods it probably isnt necessary. Do you have gauges? that is definately necessary!
Old May 12, 2008 | 02:17 PM
Neal 97 250's Avatar
Neal 97 250
If you don't do any towing you will be fine with egt's I just got II's and I am fine. But I haven't towed yet and prtobably won't till I get the cooler.
Your stock HPOP will more than likely be fine with I's. Worst case scenario it will throw a CEL but it will still run fine. I put in a 17* and won't set the CEL till 3000+ RPM.
Old May 12, 2008 | 02:21 PM
Robbgt's Avatar
Robbgt
x3. you NEED gauges however. You can always add an IC down the road, time and money permitting.
-Robb
Old May 12, 2008 | 02:28 PM
secondarychaos
-Robb
Right because you dont know for sure how high your EGT's are until you have a gauge.
EX: if neal lives at 1000 ft above sea level and you live at 4000 ASL, he's going to get alot more air in the chamber alot easier than you are. so while his EGT's may be well in check, if you assume, you may melt pistons.
Also keep in mind each truck is different in ways!
Old May 12, 2008 | 03:00 PM
Neal 97 250
Very good point, Gauges definately.
Old May 12, 2008 | 03:13 PM
secondarychaos
Also, just to be sure, do you have the proper supporting mods? like an exhaust and intake?
Old May 12, 2008 | 06:49 PM
RubberDuck's Avatar
RubberDuck
I don't think that's correct. The only thing that changes in an injector from stock to Stage 1 IS the intensifier piston. The plunger and barrel assembly stays the same.
Old May 12, 2008 | 07:03 PM
secondarychaos
My mistake!
you were right. I read somewhere (cant remember where) that you changed the plunger.
This was taken from Dpppower.com:
Originally Posted by www.dpppower.com
There is only 1 major component inside the injector that requires basic machining to increase flow:
The Intensifier Piston. The DIY Kits clearly explains how to properly machine the Piston to
achieve the desired flow.
Old May 13, 2008 | 09:09 AM
foxracing0934's Avatar
foxracing0934
Ok so the stock HPOP and no inter-cooler are fine with stage 1 DIY's but what about the stage 2's? Would i have to run a 17* or something more to safely run these?
Old May 13, 2008 | 09:24 AM
MagKarl's Avatar
MagKarl
If you plan on any serious towing or hauling you are going to need an IC if you want to run your chip. Running empty or lightly loaded you'll be fine. Loaded heavy or towing, it's drive by pyro and keep turning the chip down and downshifting till you can hold speed and keep EGT in check. I just finished a 6L IC a while back and it makes a huge difference in my rig. By the way, I still have the stock 15 degree HPOP and have no problems with it. I don't have a scanner yet to monitor ICP or duty cycle, but I don't set the CEL the way I drive.
Old May 13, 2008 | 11:00 AM
secondarychaos
You would see more with 2's if you did upgrade your HPOP. I think you can still run them with the stocker, but you wont see the full power.
Also, if you are running the stocker, and bigger injectors, you may see a CEL for low oil pressure when you hit the throttle.
Not too long ago Neal (username???edit: neal 97 f250) installed stage 2's with a 17*. He can still get a CEL at WOT.
So if you do 2's, upgrade your pump!
Old May 13, 2008 | 12:20 PM
Neal 97 250
Yup mine are 180 cc but I can hit a cel around 3000-3100 RPM. It doesn't usually light but I can make it do it pretty easy.
Old May 13, 2008 | 02:06 PM
foxracing0934
ok, the reason i ask is becuase i can afford the diy stage 2 160cc injectors and then the SD HPOP but not both at the same time. I was just wundering if i would have to wait to put in the injectors. Thanks
Old May 13, 2008 | 02:21 PM
Neal 97 250
No. Go for the injectors first. It will be the biggest expense.
Then get the HPOP when you get time. I got mine from flea bay for $350. Or the IH dealer has them for around $375 with a ~$700 core charge. Those are the 2 cheapest places I could find. I liked the e-bay because I could keep the old one and stack them one day.
