2006 E250 Wipers
Old May 14, 2011 | 09:25 PM
jide64's Avatar
jide64
2006 E250 Wipers
My 2006 E250's wipers will intermittently only work on high. No delay, no low, no washer fluid works. Should I replace motor or is there a problem with the switch?
Old May 15, 2011 | 06:52 AM
JWA's Avatar
JWA
Quite possibly the multi-function switch on the steering column---were the washer pump working etc etc it might be the motor but in this case probably the switch.
Seems to me its somewhat easy to replace, remove the upper and lower column shrouds, a few screws and connectors before it drops out. This might not be 100% correct but I'm sure you don't have to pull the steering wheel for such a replacement like in the old days.
Old May 15, 2011 | 07:43 AM
jide64's Avatar
jide64
Thanks, I will try that. It's weird it only not works on rainy days. LOL
AndysFords
Nov 11, 2015 08:15 PM
asavage
Aerostar
Oct 6, 2015 01:46 AM
mytimeistoday
Jan 26, 2015 06:38 AM
macbuz
23
Dec 8, 2014 06:16 AM
muzzleduster
Jan 27, 2009 01:20 AM
