Which front wheel bearings do I need?
Old May 14, 2011 | 01:44 PM
wyckedcombo17's Avatar
wyckedcombo17
Hello everyone!
So I'm doing a front axle shaft u-joint/front brake/bearing job and I'm having a little problem with figuring out NAPA's serial number system.
My truck is a '78 F250 4x4, 3500# Dana 44 front axle, VIN F26SCAE6084. Does that mean I'm post # B50000?
Are these the bearings I need?
Inner Cone:
BRG 368A
Inner Cup:
BRG 362A
Outer Set:
BRG BR35
or the route of individual:
Outer Cone:
BRG LM501349
Outer Cup:
BRG LM501310
Thanks for taking a gander!
Old May 15, 2011 | 01:22 AM
mikeo0o0o0's Avatar
mikeo0o0o0
B50000 is mid-year '76 (A00001-D25000). So yours is well after that, AE6084. They switched to two letters starting the serial number in 1978.
Old May 15, 2011 | 10:34 AM
wyckedcombo17
Ooooh that makes sense now! Thank you!
Is it possible that the inside of the hub is two different diameters? The ID of the bearings are the same but the OD of the cup are different for the inner/outer bearings. Should they be the same?
Old May 17, 2011 | 12:17 PM
wyckedcombo17
Shameless bump.
Is the inside of the front hub two different sizes on the inside/outside?
Old May 17, 2011 | 10:42 PM
wyckedcombo17
Guys I really need your help on this one...
Stock 8-lug Dana 44 hub, wheel bearings. Is the inner/outer hub two different ID's? Are the bearings different sizes, or just the races
1994F2507.3L
Apr 6, 2014 11:14 AM
czgunner
Sep 11, 2013 10:20 PM
Ioki
17
May 24, 2012 10:21 PM
732t37
Jan 8, 2012 05:17 PM
1972RedNeck
Jul 27, 2011 09:10 PM
