Running rough!
Old May 14, 2011 | 12:05 PM
brad7.3's Avatar
brad7.3
Running rough!
Hey fellas, my 97' psd has been having the check engine light coming on for a while, and until recently, once the engine was at operating temp, I could clear the code with my edge evolution and all would be good. But now, even after operating temp is reached, I have to clear it several times before it stays off! The code is;
p1211- inject. Control pressure above/below desired
Anybody know what this is or know what to do to fix?
Old May 14, 2011 | 01:36 PM
Ken_C's Avatar
Ken_C
check the ICP sensor its screwed into the left head towards the front. has 3 wires. check it for oil seepage. theyre not cheap but if its leaking its probably bad.
Old May 14, 2011 | 03:36 PM
brad7.3's Avatar
brad7.3
I'll take a look.
Old May 14, 2011 | 11:52 PM
oldbird1965's Avatar
oldbird1965
Brad, I get that code all the time. I replaced the ICP and IPR and still get it. The best I can figure its spikes in oil presure from my HPOP adrenaline. I see you live near TJ, when he solves your problem let me know so I can fix mine, LOL!! I'm just learning to live with it.
Old May 15, 2011 | 09:34 AM
brad7.3's Avatar
brad7.3
It's just recently stalling, and or losing all power when the check engine light comes on! It's getting irritating and I don't want it to leave me dead on the side of the road.
Old May 15, 2011 | 09:52 AM
84-250's Avatar
84-250
How does it start hot?
Does it pop the code if you are just putting around or in the throttle hard
a scangauge could help pinpoint the problem
It sounds like your leaking HP oil and you have maxxed out the IPR duty cycle. Thats if your not running huge injectors and a hot tune on the stock HPOP
ipr orings
injector orings
Old May 15, 2011 | 10:15 AM
brad7.3's Avatar
brad7.3
It's not modded, pretty much stock. Seems to start fine warm, it's mainly after it's had a chance to cool down or when it's been shut off for several hours.
Old May 15, 2011 | 10:18 AM
brad7.3's Avatar
brad7.3
It's only been doing it when I start it in the morning to go to work, and after work when I start it to come home.
SNIPER168308
Apr 21, 2012 06:58 AM
UNTAMND
Jan 10, 2012 04:25 PM
BigAlsPSD
Sep 29, 2011 09:11 AM
mrjenkins79
Sep 25, 2011 11:23 PM
mrjenkins79
Sep 9, 2011 06:29 AM
