Injector Code 1275 High to Low Open
Old Sep 27, 2011 | 08:54 PM
BigAlsPSD's Avatar
BigAlsPSD
Since the cooler weather, I have started getting an IDM code but will only set the code if I drive before the engine is up to normal operating temp. Not driving aggressively either, simply applying normal pedal pressure will trigger the SES on and off. I have no drivability issues, and there is no pronounced miss, injectors all buzz equal and loud. They are Casserly injectors and still under warranty, so I will likely send them off. My thoughts are the solenoid, and I have not verified by swapping them, however these injectors were in my previous motor, and was getting the high to low open on injector 1, I did not note which hole each injector came from and where it went in the new motor, but I can assume(I know) that this was the injector from hole 1. New motor has new UVC gaskets and harnesses, and if you clear the codes after EOT is normal there is no code present. Any other thoughts?
Old Sep 27, 2011 | 10:31 PM
slim613's Avatar
slim613
i have one injector that said high to low side open as well bit my light never came on u used a solus snap on diosnoses wen i did my buzz test and before i noticed a wire was falling apart on the VC gasket soing to the injectors and the glow plugs then a guy emailed me a code chart that tells u exacley were ur problem is and all u gotta do is find it and thats were my problem was
Old Sep 27, 2011 | 10:37 PM
BigAlsPSD's Avatar
BigAlsPSD
Yeah I've been through all of these procedures with the wiring, maybe just the IDM or solenoid, and even cold everything has check out ok.
GB_Tech_Bulletin_103_Ford IDM_Module_Replacement (1).pdf
Old Sep 27, 2011 | 10:47 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Initial gut feeling is a slightly week solenoid but I would think the issue would show itself when warm vs cold. .
Have you buzzed the injectors when the engine is stone cold?
Old Sep 27, 2011 | 10:48 PM
slim613's Avatar
slim613
Attachment 41887
dang thats gotts suck well goodluck to ya i wish i could help ya out more
Old Sep 27, 2011 | 10:51 PM
BigAlsPSD's Avatar
BigAlsPSD
Yep, no codes will show up after sitting all night, they all buzz nicely crisp and loud. Start it up no SES light, but as soon as any real load, not just backing out of drive or idling down the street will set an SES but get into the throttle even slightly if not up to OT SES will flash, immediately check codes with Scanner hooked up and 1275, Once up to temp, no SES and if codes are cleared no stored codes. Like I said there is no drivability issue, so I'm not terribly concerned.
Old Sep 28, 2011 | 02:31 PM
BigAlsPSD's Avatar
BigAlsPSD
Bumping for ideas? Thinking solenoid.
Old Sep 28, 2011 | 02:48 PM
omanalansan's Avatar
omanalansan
I just did the solenoid swap. $60 bucks Ebay. fixed my problem.
Old Sep 28, 2011 | 04:22 PM
bfife's Avatar
bfife
still plays with trucks
Alan, you're right on with the solenoid. been there done that. same symptoms as you are having. must have got mine from the same ebay guy as above $60. and done.
Can't find his card right now but I remember it said " Hector with injectors" LOL
Barney
Old Sep 28, 2011 | 04:27 PM
omanalansan
I bought it form this guy accuratediesel. Fast shipper as well.
Easy fix. hard part is getting the little screws back in with the right torx socket.
Old Sep 28, 2011 | 05:59 PM
BigAlsPSD's Avatar
BigAlsPSD
I guess I need to call Ryan and find out if solenoids are included with the warranty.
Old Sep 29, 2011 | 08:58 AM
bama29fan's Avatar
bama29fan
if not covered let me know...i have an extra solenoid.....only one but it's yours if you think it will help.
Old Sep 29, 2011 | 09:11 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
If the solenoid fails, I'd look at the IDM....
I had this problem last winter as well, I kept getting the code for Injector #1. It would shake and the only way to quiet the injector down was to run some Howes Diesel Treat.
After buzzing the injectors, I swapped IDMs with Roland aka Mueckster and the problem was solved. Bought a new IDM from here: Auto Computer Exchange | Engine & Transmission Control Units
Haven't had a problem since....
abowman
Feb 22, 2024 02:35 PM
elyrain
Jan 10, 2015 05:40 PM
Joe Bleaux
Jan 8, 2014 10:47 AM
bill11012
13
Jun 11, 2010 02:37 PM
rmcgraw351
Aug 17, 2005 04:50 PM
