Dana 50 Drop Bracket's
IMHO Theres nothing "wrong" with a D50. It's a good axle and mine has 215K on it and still has original ball joints and only now does it need pivot bushings. It doesn't wear tires out, and it's taken alot of abuse. D60's are nice axles but they too have there issues with death wobble and such. So what I'm trying to say is if the man wants to Keep his D50 theres nothing wrong about that, so don't try to give everyone the impression that the D60 is the only axle worth having, this may cause people to spend large amounts of money they don't need.
The flip side? Both of my 4wd F150s are still running the factory coil sprung TTB front end, and I have no plans of changing it. I keep everything greased up and do regular tire rotations and alignments... and have no drivability or tire wear issues. If you ask me, it really depends on what the truck is being used for and personal preference.
I have more death wobble problems with my 50 than I've had with my 60. Death wobble is always simple to cure though, comes down to poor geometry or loose/worn components.
I could see death wobble being an issue with straight axle even bump steer. It was a major problem with a Jeep Cherokee my brother used to own. A TTB would have to be pretty effed up to get death wobble, I have never experienced it with TTB.
Not everyone and their brother/sister/aunt/4th cousin twice removed needs a Dana 60.
If you never venture off road and don't have a heavy *** plow hanging off your front... you don't need a Dana 60.
If you only occasionally go off road, down dirt tracks, puddle jumping, log roads, etc... you don't need a Dana 60.
If you do off road, but you haven't broken anything... yet... you don't need a Dana 60.
When you start breaking your chit left and right, rock crawl, want to spin some large treads, dropped a heavy deeezel in your truck... well hey, you might want to consider a Dana 60.
Let's be honest, there are only so many Dana 60's in existence. How many mall crawler/trailer queen/show trucks are they are under now, that have ZERO need to be there? Why keep pushing the Dana 60 to folks who don't need the strength it offers? If you're not breaking stuff, you don't need a Dana 60. For 95% of this forum, a Dana 60 isn't needed, but it's the only answer some people will give to TTB questions. Pull up the TTB Thread, read the links, and learn how to set-up the TTB. If the only reason someone wants to put a straight axle in is for "tire wear" you are just too damn lazy to learn how to set-up your TTB right. And if that's the case, please use the Dana 44's that are laying around and leave the 60's to those who need 'em.
/rant
Not sure who had that idea? There are plenty of D44s out there that'll do just fine for light duty use with smaller tires.
Well said guys... personally I don't need a straight axle under all my trucks either. My 77 Highboy came with one (D44) from the factory, might as well leave it that way. My 79 Bronco also has a D44 straight axle, it's a wheeling rig that runs a big block with 37" tires... probably could use a D60 (I have one) because I beat the crap out of it off road. I swapped a D60 under my 84 F250 because of snow plowing, I really don't want to have to get the truck aligned twice a year. Besides I never have the same amount of weight on the front of the truck at any given time. Along with the snow plow, I also occasionally run a multi mount winch on the front. Even with regular tire rotations it still burned up tires pretty fast, of course I am also running "pizza cutter" 235/85s on it. Both of my F150s are still running the D44 TTB, both are lifted; one running 32s the other 35s. Both trucks see light to moderate off road use, I have no problems with either of them... thanks to regular maintenance. What I am getting at is it depends on how the truck is used, that is what determines the right axle for the application.
John
John
Dana 50
What brand are these last ones? I just got 2 tuff country ones and they are identical and the rear one does not fit as it has not got a cut out or angle on the rear bracket at the top where it meets the cross member!!!! mad
Rhc86
Aug 25, 2016 10:22 AM
69Flareside
Jun 20, 2016 08:55 PM
86 f250 4.9l
Jun 4, 2016 07:45 AM
RandysF150
Dec 21, 2009 06:58 AM
