Looks like you have a power steering gearbox --Saginaw? ...IF you have a Saginaw power steering gearbox.....
The firewall seal (for inside the cab) should look like the one on the right. --the one on the left is for a manual steering column.
The power steering bracket for the lower end of the column tube (engine side of the firewall) should look like the shorter bracket on the right. --the one on the left is for a manual steering column.
Bendix P/S: 1966/68 F100/250 2WD / 1969 F100/250 2WD before serial number D96,001.
Ford/Saginaw P/S: 1969 F100/250 2WD & F350 from serial number D96,001 / 1970/79 F100/250 2WD & F350.
Also 1980 and later F100/350.
The problem with the Bullnose power steering gear box is it mounts in front of the crossmember (the steering arms of the spindles point forwards --front steer spindles).
The Bumpside/Dentside power steering box (manual as well) mounts behind the crossmember (the steering arms point rearwards --rear steer spindles).
The steering action of the Bullnose steering gear box would be backwards from a Bumpside/Dentside steering gear box.
