Camper Top??
Old Jun 13, 2011 | 10:17 PM
joe_13894's Avatar
joe_13894
Originally Posted by RRranch
Your truck came with a third brake light. If your inspection mechanic follows the letter of the law then you MUST have a functioning third brake light on your camper since you won't be able to see the factory one anymore. Texas sucks sometimes but it's better than living in Maryland!
That rule stops applying somewhere. No truck campers come with third brake lights and I doubt everyone with one on a '92 or newer truck and camper is illegal.
Old Jun 14, 2011 | 05:52 AM
Brain's 97 Diesel's Avatar
Brain's 97 Diesel
I believe he is actually talking about a bed cap but some refer to them as "camper tops" as oposed to the actual RV type camper slide in unit. I think we are all discussing the fiberglass, composite, or aluminum caps w/ no floor that sit on the bed rail tops to keep your stuff in the bed dry like a tonue (?) cover does but at roof level or higher.
Old Jun 14, 2011 | 09:28 AM
jtexfisher's Avatar
jtexfisher
Yup. Camper top v slide in camper. Kinda funny that the slide in's don't have 'em come to think of it.
Anyhow...after several hours of poking around and testing every wire back there, it ain't there. So I went and found circuit 511 up in the cab and ran a new wire to the bed for the stoplight. FINALLY done with this episode.
Thanks all!
Old Jun 14, 2011 | 01:14 PM
Brain's 97 Diesel
Slide ins & trailers do not have third brake lights because they are not "passenger vehicles" and they fall under RV or off road catagories, or so my mechanic thinks. No real defination in his inspection book & HE doesn't want to open a can of worms w/ the PA Troopers you have to ask.
Glad to hear your done. My 97 had the wire in the harness. I think its always better to have it working than not.
Been thinking of adding a third brake light to my 30' TT up high for those who insist on following too close when I tow.
Old Jun 14, 2011 | 02:15 PM
RRranch's Avatar
RRranch
That is correct. SLide in campers are RV's. No third brake light required on them. camper shells are not RV's. They have to follow the rules of the truck. If it had it on the truck then it has to be on the camper shell. I am licensed in Pa to do state inspections and that is the rule there. Tx only cares that all the lights work. While I doubt anyone would ever say anything I wouldn't risk it myself.
I wish Tx would require headlight aiming for state inspection like Pa does. Too many idiots here trying to light up the sky. Also chevy trucks with one bulb upside down is really irritating!!!!!
Old Jun 15, 2011 | 07:51 AM
jtexfisher's Avatar
jtexfisher
"Too many idiots here trying to light up the sky."
NOT ME!
Hint: When you aim your headlights, do it with the LOW BEAMS.
Old Jun 15, 2011 | 09:44 PM
RRranch's Avatar
RRranch
All these cowboys out here need to do it with their horse trailer hooked on. Seriously. Trucks just don't carry weight anymore like ours do. My almost 4000 pound camper won't even engage the overloads. And whats with these stupid blue lights? I failed every one of those I ever saw in Pa. They are illegal in almost every state. Here the law says specifically that headlights must only project white light. Pa too. I just installed a tractor light on the rear bumper of my truck just for the next idiot that rides my tail with those blue lights on.
Old Jun 16, 2011 | 12:13 PM
Brain's 97 Diesel
How about the jackwagons who drive around w/ the high beams on, or low beams aimed as high beams, OR driving around on the DRL after dark. I think the worst thing is the illuminated dash that is lit all the time. Used to be it only lit up w/ the outside lights lit.
Agree about the blue lights as well.
Question??? Why does the 4 way flasher (when turned on) send a signal through the vehicle trailer harness to both the trailer turn signals & brake lights/trailer brakes? It causes my trailer brakes to pulse OR engage/lock up, and sends a fault to the ABS on truck as ABS light lights up every time. Is there a way to change this? Was thinking of running a seperate wire from master cyl brake switch to trailer harness IF I could be sure the 4 way doesn't feed in from somewhere else.
Old Jun 16, 2011 | 12:34 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
X3 about the blue lights, I hate them.
What brand of brake controller do you have, I use to have one(draw tite IIRC) and did that, and the dealer sell a special thing that stops that, but later I bought a tekonsha MP3 and no more issues, I had to take out the special thing I had installed with the other brake controller
Old Jun 16, 2011 | 12:38 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
This is the part: pulse preventer
Pulse Preventer for Electric Brake Controllers Draw-Tite Accessories and Parts 5501
Old Jul 9, 2011 | 07:44 PM
bigjim31's Avatar
bigjim31
camper top plug
i bought a shell with the 3rd eye brakelight but it has a 3 prong plug and have been unable to find anything but 4 prong and bigger.
Jetmx
19
May 30, 2017 08:26 AM
TronElkins
Mar 1, 2017 04:46 PM
AUTOHAUL
2015 - 2020 F150
Dec 29, 2016 04:29 AM
BryanF350
Feb 16, 2016 02:53 PM
big e
Sep 10, 2003 03:20 PM
