could use some help
Old Feb 15, 2016 | 04:36 PM
BryanF350's Avatar
BryanF350
could use some help
what year would this camper be? I'm thinking its a 68 but not sure if it is or not any help would be appreciated
Old Feb 15, 2016 | 04:53 PM
ultraranger's Avatar
ultraranger
Looks more like the E350 box van I pulled my front sway bar C-brackets from. It was an '87 model.
The year model should be listed on the drivers door/door jamb.
Old Feb 15, 2016 | 05:10 PM
BryanF350's Avatar
BryanF350
Unfortunately, it's not there
Old Feb 15, 2016 | 05:27 PM
Uni Moe's Avatar
Uni Moe
That's older. From the grill it looks like 78ish. Could have a 351W or 460.
Old Feb 15, 2016 | 05:43 PM
BryanF350's Avatar
BryanF350
the motor still has the Identification tag on it
Old Feb 15, 2016 | 08:46 PM
ultraranger
I'm not much up on E350 chassis cabs but, you're probably right that it's probably a mid to late '70s. An '80s model would have more rectangular looking head lights but pretty sure that the one pictured is newer than a '68 model.
Old Feb 16, 2016 | 12:28 AM
GaryKip's Avatar
GaryKip
The camper should have an ID plate (sometimes it's just made of paper and glued ) on the inside somewhere. Some plates are on the inside of a cabinet door. Others are on the electrical panel/control box. A few states require them on the outside near the door.
Old Feb 16, 2016 | 01:33 AM
RichS2659's Avatar
RichS2659
It is a 75-78 as there is no square headlights and with no cube grill. Just like the Dent 73-75 grill. Check the safety certification sticker under the driver door striker post for the actual date if the metal warranty plate is gone. Also check the EPA model year emissions compliance sticker date located on the radiator, fan shroud, or core support.
Old Feb 16, 2016 | 03:21 AM
JEFFFAFA's Avatar
JEFFFAFA
2X. 1975 was the 1st year for that Econoline body style.
Old Feb 16, 2016 | 06:10 AM
jowilker's Avatar
jowilker
BryanF350 Welcome to and the Bumpside Forum.
Unfortunately you posted in the wrong forum as your photo is of an E series not a F.
Agree with Jeff on series start, headlights when square edge in 78. So 75-77 should fit.
John
Old Feb 16, 2016 | 02:53 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
It has round headlamps and the new body shell introduced in 1975 = 1975/78 E150/350 (Econoline).
Beginning in 1979, Econolines have rectangular headlamps, the lower grille panel is also different. Both the grille and lower panel are the same thru 1991.
With a Class C motorhome body, this is an E350 Cut-Away (see pics).
haleakala
Feb 9, 2017 07:06 PM
JWA
WTB - Parts & other
Oct 10, 2010 10:07 AM
Fat Diesel
Oct 25, 2008 07:57 PM
robertbourque
Apr 3, 2007 02:51 PM
emgee
Oct 3, 2005 04:29 AM
