volare disc brake dragging
Old May 13, 2011 | 02:58 PM
cookieman69's Avatar
cookieman69
I have 1955 f100 with volare front end I will list what I have and what I have done to see if anyone has ran into this before , volare clip GM duel master cylinder, 8 inch power booster ,3/16 lines( steel ) rebuilt calipers ,new rubber brake lines residual valve I have checked clearance on rod between m/c and booster 1/8 inch there is play in peddle to m/c when sitting still front wheels turn fine after driving 2 miles front brakes start to lock up further you go hotter they get let cool off ok again same thing again when I go down the road. tryed experamint yesterday when they cooled off I went down road never touching brake and they started dragging again any ideas Thanks Michael
Old May 13, 2011 | 03:30 PM
sdetweil's Avatar
sdetweil
so, it sounds like the booster is pushing on the master rod. just for grins, unplug the booster vacuum, plug the manifold or hose depending on which end you disconnect, leaving the booster with no vacuum.. practice stopping without boost.. make sure you know what you're getting yourself into. test drive
also, maybe the pedal is bouncing against the booster (unlikely)
the booster is probably heating up from the drive. is this under the floor?
Sam
Old May 13, 2011 | 03:32 PM
GreatNorthWoods's Avatar
GreatNorthWoods
Make sure a 2 lb residual valve is plumbed into the front and not a 10 lb. I think you could also increase the clearance on the MC push rod to 1/4 inch. That would help some...
Old May 13, 2011 | 03:59 PM
sdetweil's Avatar
sdetweil
good points.. I missed the residual comment, so this must be under floor..
and you could back off the clearance, finding that clearance balance in city traffic is pain.
Sam
Old May 13, 2011 | 05:34 PM
cookieman69
Sam
I am having trouble getting a full pedal so i don't want to have anymore play than needed on booster rod I understand as little as 1/16 is ok when this happens I have gotten out and checked for heat in the lines, booster/master cylinder and the only thing that is hot are the calipers ??
Old May 13, 2011 | 06:13 PM
sdetweil's Avatar
sdetweil
well, the fluid is designed NOT to expand or contract. so that ain't it.
you've replaced all the wheel end parts, so THAT ain't it..
we're down to the booster, master or residual valve. never heard of a residual doing this..
sam
Old May 13, 2011 | 07:06 PM
BBKtech2's Avatar
BBKtech2
I thinking the residual check like mentioned. Are you sure its a 2lb in the front? Are you sure its plumbed in line in the proper direction? This sounds just like when we used to use the single resivoir fruit jar master cylinders with discs and you had not removed the check valve, the front brakes would apply and heat up.
Making sure the back brakes (if drum) are adjusted up all the way will bring up a low pedal. The huge Volare caliper puck requires quite a bit of fluid to move, hence more pedal travel when applying.
Old May 14, 2011 | 12:33 PM
cookieman69
update
unhooked vacume line booster went down road came back jacked up truck all 4 wheels dragging bad, cracked front brake line front wheels freed up figured m/c not releaseing pressure got in truck pumped pedal 20 times didn't lock up wheels only drags when driving down road ????
Old May 14, 2011 | 12:43 PM
sdetweil's Avatar
sdetweil
Well, that means its the residuals probably. Are u sure they are 2lb for disk?
All 4 hung up sounds odd tho
Sam
Old May 14, 2011 | 12:51 PM
GreatNorthWoods
Are you using a combination valve with the GM master cylinder? Is is possible you have the combination valve plumbed incorrectly? Do you have a high heat source close to a front brake line (like exhaust headers)? I have had a similar problem on two ocassions. On one the front brake lines were clogged and on the second the MC push rod was too long. I have run out of ideas as to what it could be.
Old May 14, 2011 | 05:45 PM
cookieman69
I removed residual valve same thing without it I suspect m/c might be to blame but why dosen't it build pressure when I pump it garage
Old May 14, 2011 | 05:58 PM
sdetweil's Avatar
sdetweil
and he said all 4 were hung up..
Sam
Old May 14, 2011 | 06:32 PM
GreatNorthWoods
If you figure out what it is I'd surely like to know. Somehow the fluid is expanding in the lines causing pressure that is not being relieved or once the fluid leaves the MC, something is not allowing it to drain back...
raerjim
Apr 17, 2013 06:02 PM
jm5770
Feb 9, 2009 09:21 PM
merc546
Aug 25, 2007 06:20 AM
merc546
Nov 7, 2006 08:14 PM
cwpowell
Oct 25, 2003 01:32 PM
