Noise in steering column
Old May 12, 2011 | 09:00 PM
old ford man 47's Avatar
old ford man 47
I installed a 1979 tilt column in my 1972 and when I turn the wheel it sounds like an air leak.Anyone have any suggestions Thanks.
Old May 13, 2011 | 05:12 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I will throw out a guess, after a few questions.
Does you truck have power brakes, IE a power brake booster?
How are you brakes working?
Does it do it when setting still and moving the wheel or when driving also, like when making a u-turn?
Did it start this after installing the the tilt wheel?
Did ?, just curious. Was the 72 wiring harness a PITA to wire up to your 79 harness?
Old May 13, 2011 | 06:37 PM
old ford man 47
The brake booster was the first thing I thought because I was on the brakes but without being on the brakes it makes the noise.It doesn't bother me just very curious as to what is doing it.I just cut the wires on both and soldered them to the 72 plug. Thanks
Old May 13, 2011 | 11:09 PM
77&79F250's Avatar
77&79F250
Well that was going to be my guess too.
Old May 14, 2011 | 03:52 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
A 'sheeshing' noise eminating from the steering column is a sign of worn upper and/or lower steering column bearings.
Old May 14, 2011 | 04:02 AM
77&79F250's Avatar
77&79F250
ND to the rescue again, thanks.
Old May 14, 2011 | 09:26 AM
old ford man 47
I thought it might be something like that but it wasn't doing it in the 79.It doesn't feel loose and works great .Wit the tilt I can get in and out without banging my leg .Now to get started on putting the 57 on the 79 frame.Thanks for the help was mostly curious as to the noise.Again thanks
jsnbuck
Feb 16, 2013 02:45 AM
52' fordnut
Dec 10, 2012 07:51 PM
wadar1969
Nov 5, 2010 06:22 PM
dfwdiesel
Dec 13, 2007 09:08 PM
ford-nut
Feb 25, 2005 07:35 PM
