Locking Hub Question
Old May 12, 2011 | 08:15 PM
NMRancher's Avatar
NMRancher
96 F250, build sheet indicates automatic hubs, but I am the second owner and it has locking hubs secured w/ allen-head screws of unknown size.
Problem is the screws are not any size I have, they really do appear to me to be 4mm bolts w/ a 3.5 mm allen head. wtf? I don't have the best set of calipers, perhaps they are SAE and the tool size is, what, 9/64? Whatever size it is, I don't have it in 3 sets of wrenches, 2 SAE (but no /64 gradations) and 1 Metric.
I've googled 3.5 mm allen wrenches, they do exist but are apparently rare, I can't find one in town at the usual suspects (Lowe's, Sears, Auto Zone, a few other local places).
What the hell size do y'all think this is? Any ideas on how to remove them?
Damn thing also has 21mm fasteners all over the front end. What. The. F
Thanks for reading!
Old May 12, 2011 | 08:21 PM
Talyn's Avatar
Talyn
3.5 mm is standard. I have like 3 of them.
Weird you cannot find them.
your hub looks weird whats up with it?
Old May 12, 2011 | 08:32 PM
NMRancher's Avatar
NMRancher
Well, that was fast. Any idea where I can find one online? I did find a single at metric-tools.com, or something, but they wanted like $30 to ship (not kidding). I also have a garage full of Japanes motorcyles, two things I've never seen on those are 21mm hex heads and 3.5 mm allens (or 13 mm hex heads, for that matter).
That hub got ground off on a high curb. It is stuck in the locked position, so I have 4wd, but I cannot release that side. The plastic part just spins, it is no longer connected to the mechanism inside.
Thanks for the reply Talyn.
Old May 12, 2011 | 10:09 PM
axel 56's Avatar
axel 56
I just went and checked my warn locking hubs and the allen key was 1/8
Old May 12, 2011 | 10:15 PM
axel 56's Avatar
axel 56
My metric set does not have a 3.5 it goes 2,5 / 3 / then 4 and the 4 is to big and the 3 is to small
Old May 12, 2011 | 10:39 PM
Talyn's Avatar
Talyn
t15 or a t20 torx bit is what I use after i break them loose with an allen key.
Try that. I think its t-20.
Old May 12, 2011 | 10:45 PM
NMRancher's Avatar
NMRancher
the torx bit works on the good hub, but it slips on the other one, even w/ an impact wrench.
I was going to just drill the heads off and be done w/ it, but I'm not sure I can easily replace them.
Old May 13, 2011 | 07:35 AM
Talyn's Avatar
Talyn
I'm not quite sure what your referring too. its quite strait forward.
You pull the allen screws out of the cap, pull the cap and inside there are no more screws you need to remove.
Old May 13, 2011 | 07:40 AM
Copedawg's Avatar
Copedawg
Not sure if you can see this or not. If not you can pm me your e-mail and I can send it to you, if you need/want it
Old May 13, 2011 | 07:47 AM
Talyn's Avatar
Talyn
I'll take a copy of it IAN.
Old May 13, 2011 | 08:58 AM
NMRancher's Avatar
NMRancher
I'm not quite sure what you're referring to?
Still no luck finding a 3.5 mm online, single or as part of a set, except for at metric-tools.com for $20 in shipping charges.
Edit: okay I just bought a single from Carpentercreek.us.
Meanwhile I'll get to work on swapping the TTB busings, I may have to start a thread about that....
Old May 13, 2011 | 08:59 AM
Talyn's Avatar
Talyn
The hub is obviously trashed.
Just use a left hand drill bit and drill those heads out. So much easier, you wont re-use the machine screws anyways.
Old May 13, 2011 | 09:10 AM
Copedawg's Avatar
Copedawg
On the way Keith
Old May 13, 2011 | 09:34 AM
Talyn's Avatar
Talyn
Thanks buddy.
Old May 13, 2011 | 09:51 AM
Higgy's Avatar
Higgy
Got a fastenal store nearby? That's who stocks ours here at work. Not sure of a price but willing to bet they'd have one on hand.
