It's a 2004 250, with low power. The last owner had put in a few injectors, but complained of no boost.
It has codes P0299, P1408, and P2253.
It has a new turbo, new VGT, new EGR and cooler. and still the same problem with the same codes. Im at a dead end. Anybody got my solution?
Thanks
<!-- / message -->
Chaffing wire harness, check the EBP SENSOR wiring harness back by the y-pipes,it will have the ribbed wire protector around it but that doesn't mean a thing the wires will still melt inside it.
Forgive my typing skills. The code is P2263.
No there is no tuner. I am checking the pipes and EBP harness now. The CAC tubes are ok
Also check the map sensor and it's hose (attaches to passenger side of intake manifold) and see if the hose and intake nipple are plugged. From all these codes I'm thinking serious leak somewhere or a wiring problem. Is the EGR valve installed and plugged in?
