Had the diff checked today.fluid was grey in color,looked like it might have a little water in it. 2010 limited slip. wasn't over full. 10000 miles.Any thoughts?
How was it checked with out removing the diff cover? Did you extract some with a turkey baster through the fill hole?
Yes it was extracted through the fill hole. It didn't look too bad but def had a grey color to it. I will have to check to see if there is a check valve on the vent.
The diffs are filled with synthetic gear oil and the rear diff has a 150K mile change interval, at least that's the case with my '04 Expy. If I were towing I'd likely reduce the interval to 100K miles.
I think I'd talk to the dealer about this one as it's still under warranty.
The gray color comes from the white marking compound used when the axle is set up at the factory. There is a special service message from Ford about this topic.
