Rattle from exhaust
This might be a number of things, but it could be as simple as a heat sheild rattling.
I'd suggest crawling under the truck, when it's not running, parking brake on, and when the truck is cool (like after sitting all night) and begin tapping on things with your hand/fist, or a dead blow mallet. Something will rattle eventually.
Welcome to FTE and good luck.
I agree with Millzy. I had the same noise on my Jeep, sounded like ball bearings in there. The CAT was coming apart inside and after a while the check engine light came on indicating that the cat was not functioning properly. One thing to keep in mind. When they do start to break down, small pieces will come out of the tail pipe on when you gun the engine. The thing you have to be concerned with (and I have seen this) if too big a piece breaks loose it can block the exhaust and then things get bad quickly. I've seen the entire exhaust pipe from CAT to manifold glow cherry red because it was blocked. This my friend can and will catch something on fire. Don't ignore it.
I too thought about this when you said it happened during acceleration. I believe you have a problem with the IWE's in the 4wd system.
Here's a thread to read through:
https://www.ford-trucks.com/forums/8...then-some.html
Does your rattling happen within a certain RPM range when accelerating? My 07 has a rattle that sounds like a loose heat sheild but I have checked anything that could be loose under the truck and nothing seemed loose or would rattle. My rattling only occurs between 2.6 and 2.9k RPM. It has rattled since I bought it last year and since then I have installed a Magna flow CAT back. I will also look into the vaccum lines as earlier posted (I just replaced my vaccum valve for the 4x4 three weeks ago).
okiebronco
07-08-2003 03:26 PM
