i don't go over there because their stupid black background with white letters is very bad for people with vision problems. less than 2 minutes there gives me a blinding headache.
any plans to guard the rear tie rod? Seems to be hangin out there waiting for a rock to grab it and bend it. That would be the end of your wheeling, possibly leaving you stuck until you fix it.
Build looks great man! You definitely have some fab skills thats for sure!
Thanks for the compliments, as alpha said the tie rod is just on there to keep the wheels pointed the right direction. I still need to get another ram and build the rear steer setup
Originally Posted by alpha/omega
He still has to build the full hydro deal for the rear. That's just a tie rod to keep both rear tires pointing the same direction.
Yup
Originally Posted by crazyredneckanyhow
I make the motion to leave the trailer tires on when its done and do a 4wheel burn out. Can i get a second on the motion?
Ok, you talked me into it. I'll have to strap it to something and do a 4wheel burnout
