Offroad & 4x4
Lucky13's build
Old Jun 24, 2011 | 01:41 PM
  #31
lucky_thirteen's Avatar
lucky_thirteen
Finally got off my *** and finished the other two wheels for it
Here's the basics of how I recentered them.
Step 1: Probably the most important step. Remove the tire from the rim/break the bead and a put a block in to keep it from reseating/or do like I did and holesaw a hole in the tire. You don't want a tire blowing up on you. Then cut the center out
Step 2: I broke the bead on the trailer tires ( a bottle jack and a heavy truck works quite well for this), and used some prybars to pry one side off the wheel. Cut the center out
Step 3: I put the wheel on the welding table, and used some scrap steel to set the backspace. Take a bunch of measurements to make sure it's centered, and weld away. Reseat the tire, and fill with air
Old Jun 24, 2011 | 03:18 PM
  #32
alpha/omega's Avatar
alpha/omega
Looks good.
Old Jun 24, 2011 | 04:54 PM
  #33
hav24wheel's Avatar
hav24wheel
Not too shabby. Looks like a low rider at the moment...
Old Jun 26, 2011 | 10:11 PM
  #34
lucky_thirteen
Originally Posted by alpha/omega
Looks good.
Thanks guys. It is a lowrider right now, but it's a lot easier to work around the smaller tires. I'll have to paint the wheels chrome or gold sometime
Cut apart some old driveshafts this weekend. This is the easiest way I have found to do this.
Grind the weld down
Make two cuts, opposite sides
Cut around the weld, then hammer a chisel into the cuts you made
You'll be left with a pile of drive shaft parts
Old Jun 26, 2011 | 10:25 PM
  #35
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
Something to consider. You may want to wait until the rim is FULLY cooled until you reseat the bead. Several hours if not overnight. I have seen some bizzare things happen when a tire is seated on a rim that has had direct head applied to it.
The gases that are created build pressure and heat, more heat is more pressure and it could be 30 minutes later but the resulting explosion has flipped over trucks...
Better be safe than dead.
Old Jun 27, 2011 | 02:26 AM
  #36
hav24wheel's Avatar
hav24wheel
For the drive shaft cutting, I use a chop saw, and grind down the weld, just rotate the shaft by hand, and when u get through the weld, pop the end right out with a wack from a BFH.
Than its super easy to pound the yokes back into the tube if needed,
Easy to get strait if you pound them into thee tube, install the shaft, and rotate it by hand to see it its strait. Than weld it when its still installed, so you can get one continuous bead.
Old Jun 27, 2011 | 02:35 AM
  #37
hav24wheel's Avatar
hav24wheel
Homotalkinboutdicksallthetime
Old Jun 27, 2011 | 11:57 PM
  #38
lucky_thirteen
I did hose them off and cool them completely, but in hindsight I should have waited a while.
Originally Posted by fatdan460
***dick joke because i have nothing to add***
:flipoff:
Old Jun 28, 2011 | 12:04 AM
  #39
fatdan460's Avatar
fatdan460
have you wheeled on those big claws yet or no? had some buddies run them in 35's on muddy trails and kind of got mixed feelings as to how good/bad they were. uncut the lugs seem like they are too close to me to clean out anything muddy. i guess i mean what good is a 46'' tire if it's a slick and they don't really seem to have good lug spacing for rocks either, but i don't rock crawl.
Old Jun 28, 2011 | 07:43 AM
  #40
alpha/omega
Im going to say "no" since the truck appears to be about 3/4 done :flip:
Im really diggin' this buid. Great job.
Old Jun 28, 2011 | 10:24 AM
  #41
fatdan460's Avatar
fatdan460
he has more than one truck fool, didn't know if he used them on another one or not.
Old Jun 28, 2011 | 06:22 PM
  #42
hav24wheel's Avatar
hav24wheel
Dan is dirty.
Old Jun 28, 2011 | 09:52 PM
  #43
kjett's Avatar
kjett
its not smart to reuse rubbers
Truf! Last time i tried to reuse a rubber, Kris appeared 9 months later.....
Old Jun 28, 2011 | 10:07 PM
  #44
lucky_thirteen
Never used the claws, I'll do some cutting to them eventually. It really needs a set of the 54" TTC claws
Old Jul 2, 2011 | 01:48 AM
  #45
fatdan460's Avatar
fatdan460
sorry to hear about the big C coming back man. kick it's *** for sure if that's the route you wanna go. if not live it up mang
