Truck Wanders!!!
Old May 10, 2011 | 09:58 AM
dthompson's Avatar
dthompson
Truck Wanders!!!
Got a 00 f250 with 220k. Noticed it likes to wander. Any ideas? one wheel bearing a year old check other doesn't seem to have play, and new ball joints a year ago. any suggestions? thanks
Old May 10, 2011 | 10:27 AM
MR5x5's Avatar
MR5x5
Have you checkecd the Pitman arm ball joint? With the truck not running have someone turn the steering wheel from resistance to resistance - Put a hean on the end of the Pitman arm and see if there is lash.
Old May 10, 2011 | 10:49 AM
cps's Avatar
cps
I had the same problem. Changed the sway bar and track arm bushings and that fixed the problem.
Pequeaford
Feb 5, 2013 08:00 PM
deadeyedevon
1978 - 1996 Big Bronco
15
Jan 4, 2010 06:12 PM
jons66f100
19
Aug 28, 2005 12:53 AM
trimman
Mar 30, 2002 10:03 AM
KevinT
Sep 2, 2001 06:25 AM
