Sponsored by: Real Truck
wandering
Old Jan 26, 2002 | 05:21 PM
trimman's Avatar
trimman
wandering
Old Mar 23, 2002 | 07:19 PM
slammer's Avatar
slammer
wandering
Can anyone tell me why my SD "wanders" when I'm driving down the road. I am constantly correcting it. I just put new tires on it(285s) and it seems worse than the old ones(also 285s). The shop that put the tires on said that my toe might be off a bit as the other tires seemed to wear a little uneven. I bought a rancho steering stablilizer but havent put it on yet. the truck only has 26k miles on it and it's a "tar baby".
Any ideas........
thanks
Jerry
2000 250 4x4 EC 5.4L 285/75/16
Old Mar 23, 2002 | 07:25 PM
lodihoseman's Avatar
lodihoseman
wandering
What kind of pavement does it wander on?
I know that on concrete freeways, tires will track with the grooves that are finished into the cement. Some tires will follow these grooves more than others.
Try it on an asphalt road. Does it wander on the smooth asphalt?
Just a suggestion.
Old Mar 23, 2002 | 07:29 PM
slammer's Avatar
slammer
wandering
yeah, unfortunately, it does it on concrete and blacktop.
Old Mar 23, 2002 | 07:33 PM
GRUMPY_ FD's Avatar
GRUMPY_ FD
wandering
Did you say 26000 miles on a set of tires? Thinking you had better get to the alinement shop and hurry.
Old Mar 23, 2002 | 08:12 PM
4x4x4x4's Avatar
4x4x4x4
wandering
The caster setting is what makes a vehicle want to stay on center and helps the wheels straighten themselves after turning a corner.If you do have the alignment checked I would have them pay particular attention this setting.Though it could very well be your new tires.Some handle better than others.
Old Mar 30, 2002 | 10:03 AM
slammer's Avatar
slammer
wandering
just a note to let you all know that I put the steering stablizer (Rancho) last night and it seemed to have solved the problem. BUT..... I am going to have my dealer check ALL the ball joints as well as check the alignment. Seems there are too many posts about ball joint failure to ignore.
Thanks everyone
slammer
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
