84 f150
Old Jan 30, 2013 | 08:44 PM
Pequeaford's Avatar
Pequeaford
84 f150
Im looking to buy a 84 f150 4x4. Motor rebuilt recently bored .40 over. It's a 4.9. Wandering any common problems I should be looking for with the year.
Old Jan 31, 2013 | 11:55 AM
Franklin2's Avatar
Franklin2
Rust. All the other common problems are fixable.
Old Jan 31, 2013 | 08:02 PM
Pequeaford's Avatar
Pequeaford
Ok. Thanks. They changed it to electronic ignition to
Old Jan 31, 2013 | 08:03 PM
Pequeaford's Avatar
Pequeaford
Also what kind of milage would I be lookin at. It has a 450 cfm 4 barrel carb
Old Feb 1, 2013 | 08:34 PM
truckertrav's Avatar
truckertrav
Welcome to FTE..
Your mileage will depend on several factors...
Type of transmission
Rear end ratios
Tire size
Driving Habits.
Loaded or empty.
City driving,open road..
These are just a few..
You can figure(roughly) between 12 and 17...
These numbers seem to be average...Some get more, some less..
Keeping your engine tuned up as it should be will give you the best you can get...Hope this helps you...Trav..
Old Feb 1, 2013 | 09:04 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
4 bbl carb with bored .40 over? 12-15 mpg.
The more you bore an engine the less fuel mileage it will get. The combustion chamber has to be filled with something...
Old Feb 2, 2013 | 03:50 PM
Franklin2's Avatar
Franklin2
In case you didn't know, these late 80's 300 sixes had a computer controlled carb and ignition. They have gotten rid of this system, so that's why they changed the carb AND the ignition system. You you will be ahead in that respect(if it all works ok).
Old Feb 5, 2013 | 08:00 PM
Pequeaford's Avatar
Pequeaford
Thank y'all. It ended up getting sold before I could look at it. And how would I go about changing a transfercase gasket on a 95 f150. Its reg cab short bed auto trans with a 302
willowbilly3
Jan 21, 2018 07:05 PM
Rangerfan18
2009 - 2014 F150
Jan 16, 2018 12:35 PM
ynotsher
Oct 30, 2007 05:23 PM
