Dielectric Grease Removal
Old May 9, 2011 | 02:19 PM
fmc400's Avatar
fmc400
MSEE
Hi all - can anyone recommend a solution to clean away old, dirty, gummed up dielectric grease from underhood connectors? Soap and water? Contact cleaner from Radio Shack? Just curious if anyone has used something that has worked really well for them. Thanks!
Old Jun 13, 2011 | 09:43 PM
fmc400's Avatar
fmc400
MSEE
Just a short follow-up, in case anyone looks this up. I carefully removed each crimp terminal from the plastic housing, then cleaned each terminal in a bath of rubbing alcohol, and srubbed them down with a small homemade wire brush, being careful not to knick the insulation. After drying the crimp terminals, I re-inserted them back into the plastic housing - good as new.
Note that you can't remove the individual conductors from molded connectors.
Tim Hodgson
67
Apr 5, 2017 07:46 AM
benbuilder
Dec 9, 2015 10:55 PM
queen of spades
Mar 4, 2015 07:26 AM
bomber468
2004 - 2008 F150
Apr 21, 2008 03:16 PM
rcbisset
Electrical Systems/Wiring
Oct 13, 2002 04:13 PM
