hard shifts. vss?
Old May 8, 2011 | 07:03 AM
tony. b's Avatar
tony. b
hard shifts. vss?
Hey everyone. I have a 94 f150 5.0 a4od 4x4. I'm having a hard shift issue. What happens isit shifts fine around town. The problem starts when I drive at highway speeds for any length of time. Around 55mph the speedo starts to jump around then it starts shifting hard. Shifts really hard 1st to 2nd and also drops hard into drive and reverse. Disconnect the battery for ten minutes and its fine again until I have it at highway speeds again. I changed what napa calles the the abs sensor one the diff but that didn't fix it. Is there another sensor? It looks like there is one on the side of the tcase. If so what is it called? This is driving me nuts any help would be great.
Old May 8, 2011 | 08:31 AM
Eddiec1564's Avatar
Eddiec1564
Does the OD light blink when the hard shifting happens? On my 95 E350 bus, it hard shifted and the OD was blinking, I found the PSOM had a leaking capacitor in it causing the circut board to be dammaged. For me as I am a electronics tech, I fixed the problem, but for you, its best to replace the PSOM and have it reprogrammed for your truck tire size.
Old May 8, 2011 | 10:16 AM
tony. b's Avatar
tony. b
No the od light is not blinking. What is the psom and where is it?
Old May 8, 2011 | 10:25 AM
subford's Avatar
subford
Programmable Speedometer/Odometer Module (PSOM): A module that processes vehicle speed information for use in various electronic systems. The PSOM can be programmed to accommodate various tire and axle combinations.
PSOM:
Old May 8, 2011 | 12:25 PM
LSO1123's Avatar
LSO1123
Where is the PSOM located and and where would it be on a 93 F250?
Eddiec1564's Avatar
Eddiec1564
Another test you can do if you have cruse control installed, does it work and hold speed?
The PSOM takes the rear axle speed sensor and converts it to a 8000(may be 4000 brain fart on that) pulse per mile(PPM) square wave and sends it to the ECU and cruse control modual. Probly best to pull codes now and see what the ECU is detecting.
By the way, in Subford's photo, the infamous capacitor is the silver can(with X on top) next to the plug, top left. IF that cap leaks acid out, that area will turn green goo and then the PSOM will not send out the 8000 PPM signal to the rest of the system.
Old May 8, 2011 | 12:55 PM
subford's Avatar
subford
These photos should tell you the location.
NOTE:
Only wiring harness end of connector is to be probed.
Connect Digital Volt-Ohmmeter to Pin 4 (speed in +) and Pin 5 (speed in -).
Does the voltage increase smoothly and continuously from 0 to approximately 3.5 volts as vehicle speed increases from 0 to 48 km/h (0 to 30 mph)?
OR,
If available, a frequency counter may be connected to Pin 4 (Speed in +) and Pin 5 (Speed in -).
Does the displayed frequency of the signal increase smoothly and continuously from 0 to approximately 667 Hz at approximately 48 km/h (30 mph)?
OR,
If neither a voltmeter nor frequency counter is available, vehicle speed control may be used as a good indicator. If it works normally, then the speedometer module is at least receiving a speed input signal and the wiring and sensor can be assumed to be good.
Old May 8, 2011 | 02:06 PM
tony. b's Avatar
tony. b
No the cruise doesn't work. Thanks for the help I was lost. I'm gonna look into a new psom and see if thatfixes it. I'll post when I get it done
Old May 8, 2011 | 06:39 PM
Hunt4Fun's Avatar
Hunt4Fun
The situation describe is identical to my experience 2 years ago after I purchased my 1993 F150. Here is the thread.https://www.ford-trucks.com/forums/8...h-a-twist.html
If your problem is not resolved as yet, you might take a look at changing the fluid.
finitetime
20
Oct 8, 2022 11:59 PM
deputydog03
Mar 16, 2016 09:42 AM
Butch5
Jan 27, 2016 11:37 AM
rma714
Jul 10, 2010 05:57 PM
Merculous
1997 - 2003 F150
May 21, 2006 06:17 AM
