well ***** happens
Old May 11, 2011 | 02:33 AM
78 PEB's Avatar
78 PEB
Originally Posted by fordtrucknut77
sorry bout your luck man, I was changing the a/c compressor on my truck several years ago ( with the motor hot no less) and let the ratchet slip and straight through my radiator it went, blowing hot antifreeze all over me and the truck lol.
Years ago, I had a little hot rod 74 Chev pickup. (Yeah I used to be one of "those guys") I was fixing something simple, (I don't even remember what anymore) and got done with what I had been doing. I got in and fired it up. I had forgot and left a pair of pliers laying on the top of the radiator shroud. I throttled it up and heard the dreaded "FRANG" Shut it off and got out and saw antifreeze running all over the ground. The pliers had vibrated off of the shroud, dropped into the fan and bounced around and somehow the fan spit them back out thru the radiator....................Not a good day since I lived about 40 miles from town and the truck was my only transportation. Had to call my girlfreind to come take me to town to buy a radiator...................
Old May 12, 2011 | 12:10 AM
Aussie_F_trucker's Avatar
Aussie_F_trucker
My bronco Is a classic land boat. Spendin most of my money on body filler and sheet metal .
Old May 12, 2011 | 12:56 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Pulled the front clip, pull the motor for a rear main leak/clutch set replacement.
Now it has a new oil pump, water pump, plugs, replaced the bend push rod, intake manifold leak fixed, timing chain set and complete gasket set. Clutch/pressure plate/throw out bearing.
Completed in day and a half with a FTE bud, fire it up sounds great..... then....next day start it to move it and LOUD POP back fire outa the intake, back thru the carb.
WTF......now
So we now are going to do a compression ck and probably end up pulling the head for either a valve job, or its new cam time???? Should of just keep the leak.
Old May 12, 2011 | 01:46 AM
Ak Ford Man's Avatar
Ak Ford Man
I always end op making new problems lol
Old May 12, 2011 | 03:40 AM
miottimouse's Avatar
miottimouse
i know the feeling well what started out as a "qwik fix" on my 79 bronco just to get it on the road asap last jan when we had 4ft of snow has turned out to be a 5 month project and almost $6000 later but its worth it when i dont have to make payments on a new one that wont get much better fuel economy any ways and somthing that you shut the hood and call a tow truck to take it to the dealer and the other fellows are right if we didnt love these old trucks we woudnt do it right? even afterall the time and money invested this bronco is realy goin to drive and steer as new [can hardly wait]
Old May 12, 2011 | 10:13 PM
MikePacey's Avatar
MikePacey
acutally if you think about it. Even if say you dropped 15,000 in your dent and you still get less mileage then a new truck. You more then make up for it when it comes to insuance. Cause think about it you don't have to carry full coverage and there cheap as dirt to insure.
Old May 12, 2011 | 11:05 PM
miottimouse
thats true in alberta cost me about 50 a month for each truck a bit more for my f250 stroker as i have that one aprased at 25000
Old May 13, 2011 | 02:27 PM
codyethridge's Avatar
codyethridge
These trucks are like females, the more attention you give the more they expect. Example; If you ever make the mistake of going shoping with your wife/girlfriend at the mall or somthing she is going to expect you to go all the time/everytime.
The same goes for the truck when somthing breaks you have to fix it.... then you either break somthing else in the atempt to fix the first problem or find somthing else broken, leaking or about to break.
Lets take a leaking/broken radiator hose for example. your obviously going to fix it then you notice at the bottom of the radiator some tranmission fluid residue around the trans oil cooler lines......what would you do......youd fix it. then while ur down there you notice it has oily residue in a few other places so you end up fixing/replacing entire cooler lines...... Then you notice there is a leaking output shaft shaft seal......ect ect
I believe this is why we refer to our trucks as (her) or (she) or even give the truck a female name.
73FOMO
Mar 19, 2014 06:08 PM
Brad Charlton
1983 - 2012 Ranger & B-Series
Aug 16, 2012 12:31 AM
79FordBlake
Apr 19, 2011 08:52 AM
canoechris
20
Apr 12, 2010 12:17 PM
joereidattvecdotnet
Jul 18, 2001 05:09 PM
