Cleaning your differential vent
Old Oct 4, 2013 | 04:23 PM
eatont9999's Avatar
eatont9999
Originally Posted by tecgod13
I got a new breather and I think it was from Jeff's Bronco Graveyard. I can't remember if it was the rear or front axle I bought it for though... I want to say it was the rear as I remember using zip ties to hold the brake lines in place while waiting for the new vent to come in.
Try this: Axle Breather Vent
Eaton, how long of a rubber hose did you use there? It doesn't look like much at all. I'd be worried that as the axle flexes it will rip out or bend either the vent or the tubing.
I would go with just rubber hose next time.
Old Oct 5, 2013 | 12:03 AM
ericconn's Avatar
ericconn
I got 2 feet of hose and it was enough to put through one of stock the holes in the frame with a few inches to spare. I'll probably just clamp some window screen mesh on the other end and call it done. Thanks for that link, I'll probably include one of those in my next order from JBG.
Old Oct 6, 2013 | 06:52 PM
Zagg77's Avatar
Zagg77
Thanks for the heads up on the vent. Never would have even looked at it twice if you hadn't pointed it out. Cleaned mine out, cut off cracked hose section and re-attached. Easy!
Old May 30, 2016 | 12:04 PM
90Ford73's Avatar
90Ford73
Breather Vent Bolt
Originally Posted by ericconn
Thanks for this. I'm replacing my brake lines and came across a blocked breather last night, thanks to a mud wasp. Any clue where to get a new breather from? I'll try to clean mine out, but it's pretty rusty.
ericconn, I replaced my vent bolt and hose two days ago, and got two new vent bolts from Ford; PN: F5UZ-4022-A, they come as a package of 2 for $20 (CDN). NOTE: they look different from the original one you have, these have shorter "snouts" with two barbs as opposed to the longer, single barb one you have from the factory. The parts guy at Ford gave me these ones, and it fits and work fine so far.
PS. I know this is an old thread and you most likely have found these by now, but if not here ya go
nddragon01
2004 - 2008 F150
Dec 6, 2024 08:54 AM
ryanparhaniemi
Jan 24, 2018 12:39 PM
ExPACamper
32
Jul 7, 2017 04:59 PM
rogerranger2122
1983 - 2012 Ranger & B-Series
Oct 3, 2016 09:22 PM
WolfCreek540
Jun 9, 2016 01:37 AM
