Front Gear Oil Leak - Ford Truck Enthusiasts Forums
Front Gear Oil Leak
Old 01-18-2018, 10:43 AM
ryanparhaniemi ryanparhaniemi is offline
ryanparhaniemi is starting off with a positive reputation.
Front Gear Oil Leak
Hello
Help
What seal is leaking or what is leaking?
I have differential oil leaking from the passenger front wheel. There is a pool of oil directly below the knuckle. I believe it is called the knuckle.
What are the names of the seal or seals that hold in the diff oil?
Old 01-18-2018, 11:04 AM
JessyJ's Avatar
JessyJ JessyJ is offline
JessyJ is starting off with a positive reputation.
Axel seals. Pretty big job to replace.There,s 1 on each side of the gear carrier, which is behind the diff cover on the front.
Old 01-18-2018, 12:26 PM
77&79F250's Avatar
77&79F250 77&79F250 is online now
Used OEM parts guy
77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.
I believe this is a some what a walk thru with pics. https://www.pavementsucks.com/thread...ement.1060708/
This a jeep, but you get the idea.
Old 01-18-2018, 07:53 PM
Blue and White Blue and White is offline
Blue and White is gaining momentum as a positive member of FTE.
Can you post truck type (eg F150 or F250 4 wd?) and also axle type (eg. D44 or D60?).
It may matter.
Also do you have front locking hubs? The front locking hubs can matter. If the oil leak is manageable, it will only occur with front hubs locked or in 4 wd setting. Put differently, if locking hubs are open and lever set in 2 wd front axle is not spinning and minimal leak (likely).
Old 01-20-2018, 10:52 AM
Hello:
I would like to add and answer some of the questions. My truck is a 1979 F250 Custom. Yes it does have manual locking hubs in the front I believe it has a DANA 44 in the front.
Old 01-24-2018, 01:39 PM
D-rat D-rat is offline
D-rat is starting off with a positive reputation.
Almost certainly the axle seals. Those are press in seals much like your hub grease seals and they push into the sides of the diff housing. The downside is that the axle needs to be completely torn down, except for the knuckles to replace, and the diff carrier removed. At minimum you may need a case spreader to get the carrier out. Be sure not to mess with the shims so you can put it back together and not alter your backlash, etc.
A shop would likely charge you somewhere in the $400 range for this job.
D 44 closed knuckle question ulfie 1961 - 1966 F-100 & Larger F-Series Trucks 2 04-05-2017 10:03 PM
Loose axle seals? 530ktmpilot 1999 to 2016 Super Duty 3 03-13-2017 01:36 PM
Front Axle Dust Excluder Seal? dwbaily Ranger & B-Series 2 11-26-2016 04:32 PM
Closed knuckle Dana 44 Rollingscrapmetal 1973 - 1979 F-100 & Larger F-Series Trucks 2 09-24-2016 06:37 PM
Seal Between End of Axle and "Knuckle"? Matt M, PA Excursion - King of SUVs 4 03-02-2016 07:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
