HIGH IDLE WHEN WARM
Old May 6, 2011 | 10:02 PM
waskin27's Avatar
waskin27
HIGH IDLE WHEN WARM
First of all, thanks in advance to anybody who takes the time to ponder my dilemma. So, I own rusty, trusty red 1990 F150 Xlt Lariat 4x4, built with the gas guzzling 5.8L EFI V-8 and E4OD 4 speed Trans. and I think almost all of the factory packages and roughly 110,000 miles. My question is, why does she idle fine when cold at about 800-1000 rpm, But while she's warming up and I give her some juice she wont come back down any further than 1500 rpm., and won't rev down to the normal range until I shut the engine off and then restart. What do you guys think the problem and solution could be. I was told by PO that there is a ADS SUPERCHIP installed by the owner before him, the sticker in the back window further backs up his story, but have I haven't taken out the EEC to be 100% sure.. Would the superchip be the culprit of the high idle, for better throttle response and such? Or Could it be the TPS or other sensors?
Old May 6, 2011 | 10:21 PM
Marine5811's Avatar
Marine5811
Check your throttle position sensor, idle air control valve, throttle body, and your throttle linkages. Before you check your tps I would check all the other parts for cleanliness or build up. It could be something as simple as gunked up or worn out throttle linkages but I would think it's more along the lines of a dirty or faulty idle air control valve.
Old May 7, 2011 | 12:33 AM
waskin27's Avatar
waskin27
Thanks for the input i'll check that tomorrow and let you know if its the problem
Old May 25, 2011 | 01:41 AM
waskin27's Avatar
waskin27
It was the tps truck runs like champ and ides at 800rpm
Josh Swager
23
Jul 8, 2016 10:58 PM
Primetime1
Computer Chips & Tuners
Feb 28, 2016 09:22 AM
imcqueen
21
Dec 31, 2015 10:55 AM
burnthelight88
Nov 9, 2015 11:56 AM
ktmrider56
Apr 10, 2012 06:52 PM
