Carb issue
Old Nov 4, 2015 | 04:03 PM
burnthelight88's Avatar
burnthelight88
Carb issue
Newer with the whole carb thing but just finished my first rebuild. I got it back on and it's already running better. But when I went to tune I noticed some issues and ended up pulling it again
1.) I can't drop my idle below 1000, curb idle set screw is completely backed off the throttle plate but they won't close any further to drop my idle and yes it's fully warmed up.
2.) fast idle cam won't move at all. I can't move it with my finger and it won't drop when I simulate hitting the throttle.
Any ideas? I'm thinking these things are probably one issues giving me two problems.
Old Nov 4, 2015 | 04:07 PM
burnthelight88
Ok I figured out the curb idle issue...the throttle plates won't close any further because the fast idle cam screw is stopping on the fast idle cam. Which still brings me to problem number 2...fast idle cam won't move.
Any help would be greatly appreciated I'm gonna be at this all night.
Old Nov 4, 2015 | 04:20 PM
Tedster9's Avatar
Tedster9
Fast idle cam is typically adjusted with throttle (engine OFF) wide open.
Sent from a pay phone
Old Nov 4, 2015 | 04:24 PM
burnthelight88
Yeah that's what I'm trying. I'm reading some really good instructions from another post. The problem is that the metal piece with the notched "V" will not move at all. That's where I'm "stuck", pun intended.
Old Nov 4, 2015 | 04:49 PM
Tedster9's Avatar
Tedster9
Hm, are you sure the throttle plates aren't binding on a gasket or spacer or something?
Linkage is free? Have an assistant floor the pedal. The butterflies should be perfectly vertical. The important thing is that the throttle should be almost completely closed at idle, and only the idle circuit in play. Only T slot exposed, like this:
Old Nov 4, 2015 | 05:01 PM
burnthelight88
Thanks for the replies. Throttle plates move fine and I didn't disassemble them for the rebuild so they should be lined up fine but I'll have to check.
I broke the idle cam free with much effort and PB blaster. I guess I should've checked functionality before that rebuild, still new at these
Old Nov 4, 2015 | 06:23 PM
Tedster9's Avatar
Tedster9
Have a vacuum gauge yet? You really need one to tune older motors and carburetors. Here's a couple links on how to avoid the most common errors (hardly anyone does this, many if not most, carbs are not setup correctly to begin with)
What's nice is once they are setup they don't need much attention after that. Don't let the gas go stale in tank or carb, that will screw all kinds of things up however. Replace ALL rubber hose in the fuel line, and use new clamps. Even better, bend your own hard line so there isn't any potential fuel line leaks near hot exhaust manifold.
http://www.junkyardgenius.com
http://www.junkyardgenius.com/holley/tune01.html
Old Nov 4, 2015 | 09:11 PM
burnthelight88
Yeah I used the vac gauge to set the idle mixture screws. I'm still having a slight issue but I think it's due to the electric choke at this point. Nothing will open the choke fully except holding it open with my hand. Positive wire to the choke has voltage and if I pull it the voltage travels through the coil spring but it doesn't move much. Fast idle cam isn't interfering with it so I think I'm gonna throw a new electric choke at it. At this point if the choke was manual I'd have no issues left.
I was able to get everything else set. Fast idles at about 1100, curb idles right at 650. Fast idle cam appears to be working fine now after much lubrication.
I'll check out the link though, but on another post here I found an amazing write up that also included many things typically overlooked.
Old Nov 4, 2015 | 09:32 PM
Tedster9's Avatar
Tedster9
There's something to be said in favor for the simplicity of a manual choke.
Old Nov 5, 2015 | 02:53 AM
burnthelight88
Well I ordered a new electric choke for $40 from AutoZone. If it doesn't fix my problem I'm going to return it and go with a $10 manual choke. I'd kind of rather do the manual choke to be honest but I am trying to keep this as stock as possible and don't really feel like messing with drilling, mounting, and running everything as it gets colder outside.
The problem is most likely a worn-out 37 year old factory carb but the only thing the rebuild didn't fix is this choke issue. I'd hate to spend $300+ on a new or reman when I can just do the $10 manual kit.
Old Nov 9, 2015 | 11:56 AM
burnthelight88
So I put the new choke on and after warming the truck up thought that my problem wasn't solved because the choke hadn't moved. Then I realized I forgot to hook the power wire back up. Once I did that it worked fine. But I'm still confused...
Why do these trucks have a connection to exhaust heat as well as a power wire? I know that some trucks only have the electrical connection and I understand how that portion works, not to mention it seems to be the only thing that makes mine move...but why won't my exhaust heat make the choke spring open? Is there some other problem that's gonna screw me up down the road?
HoustonGuy
19
May 13, 2012 07:22 AM
gudor
Apr 1, 2012 12:31 PM
yankeerebel
Nov 14, 2010 11:50 AM
76supercab2
15
Jul 18, 2006 02:55 PM
sfc11b
Dec 20, 2005 12:34 AM
