Ya, I'm going to do the "Parking" wire to a positive so I can do stuff while in drive, but I'm going to have a back up camera. Where is the black/pink wire under the dash? If at all.
Did you ever find the mysterious black/pink wire under the dash?
I too am seeking the location of this wire inside the cab.
Unfortunately, I don't believe I can defeat my reverse sensor as the radio I purchased shuts off the bluetooth phone feature when the backup camera is active.
If memory serves is a black/pink wire coming out of the column. Let me go look.
I spent a few minutes under the steering column and found a group of wires coming out of the wheel shroud that included a black wire with a pink stripe. The wires terminate into a brown plug.
I've attached two pictures - one for perspective and one closer up.
Assuming I found the correct wire, I hope this helps others.
I'll confirm that I located the correct black/pink wire when the camera arrives and I start my install.
So did djed ever confirm this wire worked for his reverse camera? I'm installing one this weekend.
I took power for the reverse lights and ground off of the 7 pin trailer harness back by the bumper. Then I ran the positive wire up along the frame rail with my A/V cable in a wire loom to signal the radio when the truck was in reverse. Little extra wire but I was running the A/V wire anyway and I didn't have to worry about tapping in under the dash. I made the camera only powered when the truck was in reverse. I know some guys might like it hot all the time or on a switch to be able to power it so they can see behind them while they are driving with trailers and such.
