power locks
Old May 6, 2011 | 11:12 AM
IDI Diesel's Avatar
IDI Diesel
power locks
My 1991 Xlt has the power locks which I hate but am stuck with. From the day I purchased the truck the lock switch on the driver door never worked the passenger locks but the passenger side switch worked. Not to big of an issue for me until the passenger side switch stopped working also. Im not really sure if its the switch that went bad or the electric motor or solenoid. Any ideas that would fix this or should i go buy a new lock assembly? Thanks guys
Old May 6, 2011 | 04:35 PM
Lazy K's Avatar
Lazy K
If I had to guess I would say that one or more of the wires inside the little rubber pipe between the door pillar and the door are broken.
You should check that there is 12v at the lock switch. If there is then operate the switch and check for 12v at the lock actuator (inside the door). If there is, then check that there is a good ground to the actuator.
If all is good then the actuator may be bad.
Old May 6, 2011 | 04:42 PM
F150xlt's Avatar
F150xlt
Here's the schematic for a 88. Can't say if the color code of the wiring
is the same for a 91, but 87-91 used the same switches and actuators.
12 volts used to power the circuit comes from Fuse 12 which is a 30 amp.
circuit breaker.
Both switches must be in the circuit for the door locks to work.
Old May 6, 2011 | 05:29 PM
IDI Diesel's Avatar
IDI Diesel
thanks guys ill be home next week and check this out.
bluef72
Oct 17, 2013 11:26 PM
jenkinsj
Electrical Systems/Wiring
Mar 10, 2013 08:14 PM
FordF350Baby
Nov 14, 2009 04:04 PM
jonboy88
20
Jun 12, 2006 03:35 PM
kahnos
Jun 12, 2006 06:13 AM
