Lug nuts breaking
Old May 4, 2011 | 07:19 PM
f-250diesel's Avatar
f-250diesel
Exclamation Lug nuts breaking
well i think i have a pretty serious problem, i noticed a slight banging noise coming from my passenger side wheel, so i checked it out and i seen that 3 of my lug nuts have broken off. I do not understand why my lugs would break. Also do you have to take off the caliper to replace the lug bolts. man this is kinda really worrying me any input appriciated. thanks. Nathan
Old May 4, 2011 | 07:31 PM
Fullcrew7.3's Avatar
Fullcrew7.3
I've broken a few off the rear drums before. Guess I tightened them a bit much....I'm not sure how the SRW front hubs are set up that way, but somebody will chime in.
Old May 4, 2011 | 07:58 PM
pjwoolw's Avatar
pjwoolw
The cause is more than likely human error. Probably a few were left loose last time the wheel was put on. But who knows. I'd replace all the studs. Check the lug nuts on all the other wheels. The hub will have to be removed to replace them.
Old May 4, 2011 | 08:05 PM
Action4478's Avatar
Action4478
I agree . In order to have heard it , they all must have been loose ...
Old May 4, 2011 | 08:17 PM
pjwoolw's Avatar
pjwoolw
One more thing. The wheel may be toast too if the holes are rounded out or the wheel bent. One tire shop bought me a set of new wheels because they did not tighten the lug nuts properly.
Old May 4, 2011 | 09:22 PM
f-250diesel
well i got new if my tire shop is the reason they are in a world of hurt, i just dont understand why it would happen now. I bought the wheels a couple years ago new so i have a waranty but i just dont get it besides they did not tighten them. It sucks cause i just had all the hub assembaly off a couple months ago. I hope that none of the rest break i did check the rest of the lugs and they were all tight but one, i just took one off of each tire to make up the difference. now i have to buy new lugs, and new lug studs, well thanks for the input
Old May 4, 2011 | 09:32 PM
95pstroke4dr's Avatar
95pstroke4dr
who took your hubs off? and what were the lugs torqued to?
Old May 4, 2011 | 09:39 PM
f-250diesel
well i was just going to do them my self but i ended up paying my machanic to do it and im not sure what he torqed them to, what the specs on that???
Old May 4, 2011 | 09:48 PM
95pstroke4dr
140 lb ft______
Old May 4, 2011 | 09:55 PM
pjwoolw's Avatar
pjwoolw
Torque depends on what is recommended by the wheel manufacturer. IIRC my Alcoa wheels are 115 lbs.
Old May 4, 2011 | 10:53 PM
jmpape's Avatar
jmpape
I tighten mine as tight as I can get them and then go a half round more!
Old May 4, 2011 | 11:37 PM
95pstroke4dr
140 on a 250
Old May 5, 2011 | 07:52 PM
f-250diesel
allright so i tightened my lugs prety tight but i am afraid that i am going to break more. The thing is they loosened up again so i tightened them again but tighter i am going to get out my torke wrench. i dont know why this just started happening but i know i did not hit any curbs with that side???
Old May 5, 2011 | 08:18 PM
F350-6's Avatar
F350-6
Do you know the difference between hub centric and lug centric wheels? Which do you have and are you using the right lug nuts? I've heard of similar issues when using lug centric nuts on hub centric wheels.
Old May 5, 2011 | 08:21 PM
Action4478's Avatar
Action4478
Wut?.......
