Radiator question
Old May 5, 2011 | 05:19 PM
Franko72's Avatar
Franko72
Molon Labe
Yep, mine are backwards. Drivers side "in", pass side "out"
So I guess it will work either way.
Originally Posted by jls8177
Can I just leave them empty or do I need to run the lines to them?
You can leave em empty. I had them capped off on my F250 for over a year with no problems. When time permits hook em all up. It will only help your trans last longer.
Old May 5, 2011 | 07:18 PM
jls8177's Avatar
jls8177
If I cut them, the weird ends of the hoses will still be on the heater core. How do you get them off?
Old May 5, 2011 | 08:40 PM
tdpower's Avatar
tdpower
What are you doing messing with the heater core lines? Those are transmission lines you're messing with. Maybe I'm missing something.
Old May 5, 2011 | 08:54 PM
PaysonPSD's Avatar
PaysonPSD
This is how to remove heater hoses at the core. LINK
But like Grant I'm confused as to why you need to remove them for the ATF cooler line re-route.
Old May 5, 2011 | 08:56 PM
jls8177's Avatar
jls8177
I'm changing the radiator and the heater core hoses are very old. I want to go ahead and change them because the ELC coolant is so expensive. Don't want to have to open the system up again.
Old May 5, 2011 | 09:00 PM
PaysonPSD's Avatar
PaysonPSD
That puts an end to my confusion. Did you check out the link in my post 19?
Old May 5, 2011 | 09:56 PM
jls8177's Avatar
jls8177
Thank you! Thank you! I'll give it a shot tomorrow or the next day. I was actually contemplating cutting the hoses and just putting a regular hose and clamp on there. Looks easier than I thought. Thanks again.
I'm not doing the tranny lines right at the moment. I just need to get the cooling system up and running. I'll deal with those tranny line some other time.
Hopefully I'm done with the questions. Thanks for the link. A picture is worth 1000 words.
Jason
Old May 5, 2011 | 09:58 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
I think so Frank. Guess I need to get off my butt and find out, but its going to have to wait untill tomorrow. When my front seal went out I called and talked to Brian at BTS and he told be to take off the lines going to the radiator and blow thru the drivers side with compressed air to backflush the passages to make sure they were clear. Im sure it would work either way!
Old May 6, 2011 | 12:06 AM
tdpower's Avatar
tdpower
Mine are original and still look good. Maybe they just need some cleaning. I'm sticking with my oem heater hoses for another ten year. I guess I should bookmark the link Robin posted but by then my computer will probably crash and loose it.
Old May 6, 2011 | 05:58 AM
429 f-100's Avatar
429 f-100
damm! i feel stupid for not looking at mine before i posted ! guess in my head im still in the early years of rubber hoses and clamps and seen many a heater core broke from trying to get hoses off. i wont just shoot off the hip anymore . sorry jls for leading you the wrong way. and robin reps sent for pics and explanation., wes
Meatball98
Mar 3, 2015 06:54 PM
jbravata2
Mar 2, 2014 07:04 PM
hhcobra
18
May 13, 2012 03:59 PM
GreenDinosaur
Dec 10, 2009 03:15 PM
allanhilliard
22
Nov 25, 2003 09:33 AM
