1978 - 1996 Big Bronco
Axles on '79
Old Mar 22, 2003 | 12:18 AM
todder53's Avatar
todder53
Axles on '79
Hey i have a '79 Bronco and want to upgrade to 3/4 or 1 ton axles. Anyone have ideas of where i can find donnor axles from another truck. Making them mount up in is no problem just need to know what type will work.
Old Mar 22, 2003 | 12:28 AM
Pentekno2's Avatar
Pentekno2
Axles on '79
This is quite a simple swap over, here is a site which lists the information needed to do so: http://www.medicine.wisc.edu/~mrm/bronco/
All you'll need is a F-250 rear axle (Dana 60) from 77 1/2 up
and the from Axle from 76-79 F-250, this of course is for the 3/4 ton swap, which is the most common, that is also for keeping the front as a Dana 44 with the F-250 axleshafts.
Another thing you could look into would be to run a Dana 60 in front and back, but that can get quite pricey and will take much more fabrication than the simple 44 Axleshaft-swap. But its up to you of course.
Good luck
-Daniel
Toyman
Jan 28, 2015 09:13 AM
79sparky
17
May 3, 2013 12:48 AM
Destroyer
1966 - 1977 Early Broncos
Feb 26, 2005 09:25 AM
Jared Putz
17
Nov 10, 2003 03:19 PM
