Part ID help?
Old May 6, 2011 | 05:18 PM
Otahyoni's Avatar
Otahyoni
Well, if i can get gears made somewhat reasonable, i'm trying to design a PTO winch using this box. Failing that, its gonna be scrap and i'll get more for the brass gear separate than if i leave it in the box...
Old May 6, 2011 | 07:48 PM
Otahyoni's Avatar
Otahyoni
Well, after actually looking under the truck, there really isn't a way to run a shaft forward.
I was looking forward to doing this. Exhaust is going to make it hard to run a shaft backwards... guess i'm gonna scrap the worm gear unit. maybe i can find a cheap hydraulic pump somewhere and put a wet kit on my truck and run a hydraulic winch.
Old May 6, 2011 | 10:42 PM
84-6.9L's Avatar
84-6.9L
We had a 68' F-500 4x4 that had a pto driven front winch and there was a hole thru the front crossmember so the shaft could pass thru it to the front bumper. I wouldn't run it that way but it did work and didnt crack or anything. Don't know how well that would work on your truck it's just a brain dropping i had. Also manure spreaders often have worm gear boxes.
Old May 6, 2011 | 11:30 PM
eatont9999's Avatar
eatont9999
Originally Posted by Otahyoni
Do you know if the gear is at the front or rear of the opening? I'm hoping its at the rear cause this may not work otherwise..
Well.....another twist today....
The shaft in the worm gearbox This mush have some torque...
New problem: I need new gears
The only ID i found on the box was:
Baughman Mfg Co
Jerseyville Ill
H 501
So far i cant find a place to get gears or any info on the specs for the box. Anyone feel like helping me out?
Those teeth needed a dentist a long time ago. looks like you need a whole new gear. Maybe you can find one of the same size at an industrial supply company.
Old May 7, 2011 | 07:39 AM
Otahyoni's Avatar
Otahyoni
As i was looking at it, i think its the TTB that bites me. I'm not cutting any holes in the crossmember cause it hold my front axle on...
If i had a solid front axle i could go between the crossmember and the axle, but theres just no room with the way it is now, and in the fall i'm dropping my truck back to stock height, and i'll really have no room...
Old May 7, 2011 | 07:43 AM
Otahyoni's Avatar
Otahyoni
That gear is about 6.75" diameter and 1.5" wide, i think i'd have a tough time finding one locally.
This is the second time i've seen a worm gear like that. The other time was the winch that raised our bi-fold door. It would raise up then drop a few inches, then raise more....scary stuff. The teeth on that gear looked about the same and the was a section that had no teeth. It was brass too...
Anyone else have an idea that i could use this box for that would make it work fixing?
Old May 7, 2011 | 09:14 AM
84-6.9L's Avatar
84-6.9L
A gun turret!
Old May 7, 2011 | 11:25 AM
Country_boy_2007's Avatar
Country_boy_2007
i am planning a wet kit for my 88. im looking for a pto and a hyd winch right now. im planning on putting a remote on the back with a return so i can run my dump trailer and seed wagons off my pickup instead of haveing to use a tractor
mikebrawn1
Jul 8, 2010 06:29 AM
NickM777
Electrical Systems/Wiring
Jan 21, 2006 08:52 PM
95250mac
Exhaust Systems
Feb 19, 2005 12:08 AM
RyanD
Feb 11, 2004 05:50 PM
chenders
Flathead V8 & Flathead 6
Mar 18, 2002 09:54 PM
