Enough flow for a 351?
Old Feb 18, 2005 | 06:49 PM
95250mac's Avatar
95250mac
I have a 1995 F250 with a 351w in it and it is time to replace the muffler.
The truck currently has a universal muffler with a single input and single output on it.
My question is should I…
1) Restore my muffler tailpipe combination back to the single inlet dual outlet (Walker part number 22402) and dual tailpipe configuration (Walker part number 45390 and 45389)
2) Put a single inlet single outlet muffler (Walker part number 22382) with the current 2” tailpipe
3) Install single input single output (same Walker part number 22382 HD muffler) with a custom 3 ½” or 4” single tailpipe.
Three points to consider….
1) Stock setup allows for better gas flow, More Horse Power
2) I do get more torque from having more backpressure with single in single out and 2” tailpipe, but with a 351 torque is not a issue.
3) HD muffler ( single in single out) with big tail pipe looks cool and is more cost effective because you only have to bend one tail pipe.
Just one final note:
I DO NOT want a loud exhaust system. Just something quiet and NORMAL. I have a 351 if I wanted more HP I would buy a 460.
Thank you for all your input.
Old Feb 18, 2005 | 09:26 PM
kens64's Avatar
kens64
My 4 cylinder daily driver has 2" pipe. Way too small.
IMO, bigger pipe, and a Magnaflow muffler will be reasonably quiet and mellow, not too loud, and flow better than any stock system. Outlets dont matter, if there is one pipe going in, having 1, 2, or 10 pipes coming out are not going to make any more power, just make the rear end of your truck look different.
If you are not looking for any noise, or performance, just stick with stock components.
Old Feb 18, 2005 | 11:38 PM
ford5.8's Avatar
ford5.8
Id go with at least 2 1/4 pipe.. You probley wont even notice a difference just changing the cat back setup.
Old Feb 19, 2005 | 12:08 AM
351M's Avatar
351M
Change to a Walker Quiet Flow with a 2.5" outlet and that should still stay quiet and flow better. Or just go with a longer turbo muffler
brider
Mar 6, 2013 10:29 AM
RockWVU
Oct 28, 2012 10:44 PM
baddad457
Apr 15, 2012 08:58 PM
ottocycle
Apr 23, 2010 09:11 AM
Pkupman82
13
Jul 27, 2005 07:59 AM
