50/50 Acetone/ATF
Old May 2, 2011 | 06:28 PM
77FordDW's Avatar
77FordDW
50/50 Acetone/ATF
I remember some time ago reading a comparison of various lubricants (WD-40, PB Blaster, etc.) and a 50/50 mix of Acetone and automatic transmission fluid being leaps and bounds better. I don't, however, remember anyone saying whether or not they could confirm the fact that this concoction was actually better than anything currently on the market.
Well - today I decided to give it a try. I'm in the process of stripping my truck to a bare frame and the radius arm nuts simply wouldn't budge. I could push a breaker bar with my feet hard enough to twist the radius arm to the point where I thought I may damage it, haha. Anyway, I went to my local Napa and bought some acetone and ATF.
The verdict - I'll never use anything BUT this mixture from now on. It works amazing! I sprayed some of it on the radius arms exposed threads and let it sit for a while. After this, I was able to break them free with the breaker bar and a short pipe. No feet/legs involved this time...just pulled with arms strength and they both broke free.
After this I decided to spray every nut/bolt I saw simply to make disassembly easier. It definitely made my life a lot easier and I now have a bare frame ready for stripping/painting.
A+ if you're looking to break some nuts/bolts free without the use of torches or heat. I highly recommend it.
Old May 2, 2011 | 06:35 PM
Canty's Avatar
Canty
good advice, thanks for posting. what type of transmission fluid did you use?
Old May 2, 2011 | 06:36 PM
pintoches's Avatar
pintoches
Thanks for the tip!
Old May 2, 2011 | 06:50 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Nice!
Josh
Old May 2, 2011 | 07:05 PM
77FordDW's Avatar
77FordDW
No problem everyone!
As far as what type of ATF, I honestly don't know. I just grabbed the generic Napa ATF. I honestly don't think it matters as long as it's ATF.
Old May 2, 2011 | 09:33 PM
impalaslayer's Avatar
impalaslayer
tried it, didnt do **** for me
Old May 2, 2011 | 10:09 PM
hasteranger's Avatar
hasteranger
yeah grassroots motorsports tested them and found the atf/acetone to be pretty potent. Its a pain to work with, though, because the ATF does NOT evaporate like every other penetrating oil, so if it drips, it makes a huge mess. And the acetone component of it evaporates very very quickly, so you gotta keep a lid on it.
It does work, but I prefer PB blaster. blaster is easy to use, doesn't require any mixing, and makes way less mess.
Old May 2, 2011 | 10:11 PM
bsiebert's Avatar
bsiebert
I second PB Blaster. Use it daily almost.
Old May 3, 2011 | 01:59 AM
78 PEB's Avatar
78 PEB
Nothing but Aerokroil for me.........................
Old May 3, 2011 | 07:52 AM
Poison Oil Racing's Avatar
Poison Oil Racing
PB Blaster is all I use, but this sounds interesting.
Old May 3, 2011 | 09:06 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Tried it, didn't like it. I now buy PB in the gallon size if that tells you anything. Nice thing is I can heat the parts with a propane torch and it sucks that stuff right in without catching fire.
Old May 3, 2011 | 09:12 AM
fast_st's Avatar
fast_st
I tend to use the blue solvent, two tanks and a sparky thing, it'll melt rust, nuts, bolts, fuel lines, bushings just darned near about everything and sometimes it'll loosen a stuck bolt. Have water handy to put your hair out.
Old May 3, 2011 | 11:02 AM
Bullitt390's Avatar
Bullitt390
I like the ATF trick as well, but prefer Howes Penetrating oil over that and PB.
Josh
jim henderson
General Automotive Discussion
46
Jul 2, 2017 12:52 PM
montanafordman
1997 - 2003 F150
16
Oct 3, 2016 11:56 AM
warren561
Sep 12, 2013 08:39 PM
cnmmopars
Jun 12, 2011 05:46 PM
NewEnglandHerdsman
25
Apr 22, 2009 02:15 PM
