General Automotive Discussion
penetrating oils...
Old Apr 17, 2009 | 11:36 AM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman
penetrating oils...
I posted this in a spark plug thread over in the super duty forum, but I figured it might be of some general interest as well:
Here's something that a friend of mine emailed to me a few days ago. (I don't know what the "soak time" was...)
(I don't have a direct link to this, so I hope this is enough attribution for the mods!)
Machinist's Workshop magazine actually tested penetrants for break out torque on rusted nuts. Significant results! They are below, as forwarded by an ex-student and professional machinist, Bud Baker.
*Don't forget the April 2007 "Machinist's Workshop" magazine comparison test.***
*They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a "scientifically rusted" environment. ***
*Penetrating oil ..... Average load*
None ............ ......... 516 pounds
WD-40 ............ ...... 238 pounds
PB Blaster ............ . 214 pounds
Liquid Wrench ..... 127 pounds
Kano Kroil ............ 106 pounds
ATF-Acetone mix....53 pounds
*The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone.*
*Note the "home brew" was better than any commercial product in this one particular test. Our local machinist group mixed up a batch and we all now use it with equally good results. Note also that "Liquid Wrench" is about as good as "Kroil" for about 20% of the price. ***
Old Apr 17, 2009 | 12:25 PM
quaddriver's Avatar
quaddriver
how big were these damn bolts such that they survived a 516ft-lb torque?
Old Apr 17, 2009 | 12:36 PM
Nitramjr's Avatar
Nitramjr
I've been swearing by Kroil for years - still using the last pint or so of a gallon my father got in the late 80's or early 90's before he retired. I use it sparingly because it is THAT good but also expensive to replace.
I may have to replace it with the home-brew mix. I wonder if the ATF they used was Dexron V or plain old Dexron. I wonder if the old bottle of Type F I have would work?
Thanks for the info, Jim.
Old Apr 17, 2009 | 01:37 PM
NewEnglandHerdsman
I'm guessing that just about any light oil such as a machine/hydraulic oil would do... Can you buy acetone at the hw store? I like to try this, but I don't want to be buying 150 bottles of nail polish remover and pouring them into a gallon jug...
Old Apr 17, 2009 | 03:22 PM
Nitramjr's Avatar
Nitramjr
I'm pretty sure that acetone is available in the hardware store. If not, I think that Goof-Off stuff is acetone based. But it probably isn't any cheaper than Kroil which is around $40 a gallon IIRC. But, a gallon lasts a long time since it only takes a few drops of the stuff.
The only thing I would miss making my own is I actually LIKE the smell of Kroil. Not in a "huffing it out of a bag" like but it is a pleasant scent. That and it reminds me of all those summers ago tinkering on VW Beetles and my old Ford Maverick......
Old Apr 18, 2009 | 12:06 AM
ford2go's Avatar
ford2go
I've used liquid wrench a lot, but I've never seen it mentioned in previous threads about freeing bolts. So I was surprised by this test. I thought that I'd been using the wrong stuff all along.
Did the article mention technique, soak time etc?
Old Apr 18, 2009 | 12:17 AM
Opossum's Avatar
Opossum
Good info Jim thanks.
Do you have a link to the original article?
Old Apr 18, 2009 | 05:37 AM
NewEnglandHerdsman
No 'possum, as I said in the OP, what I posted was emailed to me and I don't have a link. I googled "Machinist's Workshop magazine" and found some links to subscription information, but it doesn't appear to be published online. Maybe someone here on FTE is a subscriber and has that April 2007 issue, and can fill in some of the holes in what was posted...
Old Apr 18, 2009 | 05:43 AM
Jermafenser's Avatar
Jermafenser
Great article.
Looks like I'll be abandoning PB Blaster for Liquid Wrench.
What type of ATF? Dexron? Mercon? Type F?
Old Apr 18, 2009 | 05:48 AM
wendell borror's Avatar
wendell borror
I use PB BASTER, it works for what I need it for, at least up till this point.
Old Apr 18, 2009 | 05:50 AM
NewEnglandHerdsman
I agree, I alway felt PB Blaster worked better than Liquid Wrench... but at least in this test it would appear otherwise...
Old Apr 18, 2009 | 12:09 PM
Octane's Avatar
Octane
We've always used JB-80. Great stuff!
Old Apr 18, 2009 | 12:36 PM
quaddriver's Avatar
quaddriver
I got a crap load of PB, it cost me a lot, I aint throwing it out...
Old Apr 18, 2009 | 04:03 PM
Flexfuel-Dave's Avatar
Flexfuel-Dave
I'm going to mix a 50/50 batch of this stuff and see how it works.
Good point!
According to this website, we are likely looking at a thread in the 1-inch catagory.
Bolt strengths
Old Apr 18, 2009 | 04:35 PM
jroehl's Avatar
jroehl
Acetone's available all over the place. At the BORGs it's usually about $10-15/gallon.
Goof-off has a couple different formulas, but I think the more potent one is xylene-based (if it smells like the permanent markers of yesteryear, then it's xylene).
Interesting info--thanks, Jim!
Jason
