Sending Unit Wiring Diagram Please
I have a 1979 F-150 with rear and side tanks. The gauge only works for the rear tank, but not the side. I put a new sending unit in the side tank and put a ground from it to the frame and it pegs the gauge out at full. I am at a loss for what to do. Someone said that I maybe needed to clean the ground, but there is only one wire in the pigtail that connects to that sending unit, so how on earth would it be grounded. Does anyone have a wiring diagram of this to help me out? I am at a complete loss! Thanks in advance!
Yes...there is only one sending wire for each tank. I believe one is blue and the other is green/red stripe. The sending units ground to the tank....just like the windshield wiper motors if I'm not mistaken. I know they don't tie into any grounds anywhere. Check to make sure you sending unit has the correct ohms.
Haha turns out there IS a ground wire in that pigtail, it had just pulled completely out. I had to cut the entire rubber connector open to reattach a ground wire. Good news is that my gauge works! Bad news is I bought a new sending unit for nothing, and I have to buy a new connector. Oh well, thanks for the help!
Hmm...my schematic shows it grounding to the chassis...not in the harness, but I'm guessing it comes out of the harness and grounds to the chassis somewhere close by....yep...they have a pic in the Haynes manual it goes in the harness and then comes out and grounds...it looks like to the bed in the pics? Glad you got it corrected.
Cool...that makes more sense. I knew it shouldn't go back in the harness and travel far as my schematic shows it grounding right at the tank, they just don't tell you exactly where, but that it is a chassis or body ground.
diesel77
07-28-2020 11:52 PM
MFplowboy
02-13-2017 06:35 AM
ncalsurfer
06-20-2002 01:21 AM
