Camper Special Radiator
Old May 2, 2011 | 09:17 AM
jfmaz's Avatar
jfmaz
Anyone know the difference between the camper special and regular radiators. I can't remember if they are only taller, or are they wider also.
Don't you need a different radiator support for the campler spec radiator? and different fan shroud?
Old May 3, 2011 | 07:42 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Don't you need a different radiator support for the camper spec radiator? and different fan shroud?
1967 F100/250 352 & 1968/72 F100/250 360/390 optional * Super Cooling Radiator (S/CR): 26 1/4" wide / 24 1/4" high / Has a huge top tank.
C7TZ-8146-B .. Fan Shroud-Use with S/CR / Marked on the upper left hand corner: C7TA-H; D2TA-HA; D3TA-JA.
Fits: 1967 F100/350 352 & 1968/76 F100/350 360/390 all with S/CR.
C7TZ-16138-B .. Radiator Support-Use with S/CR: 1967/72 F100/350.
1967 F100/250 352 / 1968/72 F100/250 Standard/Xtra Cooling & A/C radiators: 26 1/4" wide / 19 3/4" high.
D3TZ-8146-C (replaced C8TZ-8146-K) .. Fan Shroud / Marked on the upper left hand corner: C8TA-S or D3TA-DA.
Fits: 1967 F100/250 352 / 1968/76 F100/250 360/390 with Standard/Xtra Cooling & A/C radiators (not used with S/CR).
C7TZ-16138-A .. Radiator Support-Use with Standard/Xtra Cooling & A/C Radiators (not used with S/CR): 1967/72 F100/250.
* 1967/72 F350 V8s came with the S/CR as standard equipment. Cannot recall if F100/250 Camper Specials did...or not.
Old May 12, 2011 | 03:08 PM
jfmaz's Avatar
jfmaz
Sorry sir, I got distracted and forgot to say "thank you" for the valuable information. Thank you.
Nothing Special
33
Dec 13, 2025 08:23 AM
vidaliaman
Feb 1, 2017 07:06 PM
BainbridgeBrewer
Jul 13, 2016 08:28 AM
Chris Popanz
Ford Truck Parts for Sale
Oct 30, 2015 09:47 PM
vettman
Oct 24, 2015 02:58 PM
