correct radiator
Old Feb 1, 2017 | 06:55 AM
vidaliaman's Avatar
vidaliaman
correct radiator
1971 camper special, 300 straight 6, no A/C, having local oreilly auto parts looking for me, this radiator needs flange towards front of truck, not engine side, the radiator they show works for this truck has flange on engine side, would also like a shroud but need to find correct radiator first, i may have to go to 800 radiator but trying local first, any thoughts?
dave
Old Feb 1, 2017 | 07:38 AM
idealtrucks's Avatar
idealtrucks
I had the hardest time finding a radiator for my 300 when it went bad. The auto parts kept trying ones for a 300 and non would work. I ended up ordering one for a 390, and found a hose that would work for the bottom.
Old Feb 1, 2017 | 07:45 AM
vidaliaman's Avatar
vidaliaman
that's what i'm going to do, do you have a shroud on either one of your 70's?
Old Feb 1, 2017 | 08:33 AM
willowbilly3's Avatar
willowbilly3
They didn't come with a shroud afaik.
It's been a lot of years since I put one in my 72 but the one they sent fit. Not sure how you put a 390 rad, the 300 has it's own core support with a lot smaller opening than the V8s. Was the provision there for the wider radiator?
Old Feb 1, 2017 | 09:51 AM
vidaliaman's Avatar
vidaliaman
good question,
Old Feb 1, 2017 | 12:51 PM
JEFFFAFA's Avatar
JEFFFAFA
What is the size of the core in your old radiator? Would this work?
Part Number: A320 Manufacturer: SPECTRA PREMIUM INDUSTRIES Boucherville, Quebec, Canada
Old Feb 1, 2017 | 12:54 PM
vidaliaman's Avatar
vidaliaman
i saw that one on line, o reilly found one for me, that one i'll bet would work, it's even less expensive then o reilly's, if the one oreilly gets me doesn't work i'm going to look into that one
thanks
Old Feb 1, 2017 | 12:55 PM
jas88's Avatar
jas88
Does anyone sell a new radiator for this truck with brass tanks as the original? I can only find plastic or aluminum, both of which are unsuitable for a restoration IMO.
Old Feb 1, 2017 | 12:57 PM
vidaliaman's Avatar
vidaliaman
good question, look forward to the answer to that
Old Feb 1, 2017 | 01:01 PM
idealtrucks
My truck had the wide opening already in it. Maybe that's why I had such a hard time finding a radiator. Didn't the 300's with ac come with the wide radiator?
Old Feb 1, 2017 | 01:03 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The tanks were originally painted black, so no one would know whether the replacement radiator tanks are plastic or aluminum, if you paint them black.
Old Feb 1, 2017 | 01:25 PM
JEFFFAFA's Avatar
JEFFFAFA
The radiator I listed above is a A/C radiator.
Old Feb 1, 2017 | 07:06 PM
jas88's Avatar
jas88
Phooey. I can easily tell the diff between the plastic ones and the original in the pics, much less in person. It's pretty obvious. Remember that these are not crossflow radiators where the tanks are on the sides, the tank is right up on top and prominently displayed when you open the hood. I know you already know this, Bill.
The aluminum ones are even worse as they have no fins or indentations in the tanks, they are just smooth across.
benwantland
Jan 29, 2023 06:35 PM
dyoungen
Feb 9, 2013 09:01 PM
livinjeep
Apr 30, 2012 07:39 AM
JReagan90
Jul 3, 2011 02:44 AM
