Offroad & 4x4
strait 6 or v8?
Old May 4, 2011 | 11:33 PM
  #31
fatdan460's Avatar
fatdan460
any idea what the chaindrive thing is on the side? or do you figure it's just for looks?
Old May 5, 2011 | 01:52 AM
  #32
hav24wheel's Avatar
hav24wheel
Dan, sometimes tHat chain drive is for the steering. Changes the ratio of the box, and moves the shaft to a location that isn't in the way.
And sometimes its just. For looks.
Old May 5, 2011 | 09:53 PM
  #33
alpha/omega's Avatar
alpha/omega
IIRC its for looks.
I think it would be bad *** if it shifted the tranny.
Old May 21, 2011 | 07:54 AM
  #34
JohnMcD348's Avatar
JohnMcD348
I'll say, it depends on what you really plan on doing with it. If it's for a DD, occasional load hauling and go anywhere, do anything truck, stay with the 6. If you just want something that gets there fast and does whatever you want, go with the 8. The fuel economy won't be as good, parts for the 8 will probably be easier to get than for the 6. I have a 4.9(300) in my 92 Bronco behind a M5OD, probably the same setup you have and couldn't be happier. I really don't have a need for a V8 in it for DD and off roading. The only reason I wouldn't haul with it is the short wheel base and gearing. I have along wheel base truck for that if I need to. The 6 will get you there and anything you want to take with you. It just may not do it as fast and as loud or cool sounding as a 351 would.
In your case, since you have both motors and the ability to switch it out, I'd say just go with your gut and decide what you want to do. Perhaps call the state, tell them your situation and see if they can give you a reasonable work around to your delima in regard to plates and VIN.
Old May 22, 2011 | 08:04 AM
  #35
77mud's Avatar
77mud
Originally Posted by JohnMcD348
I have a 4.9(300) in my 92 Bronco behind a M5OD.
Hows that working out for ya? having the trans in front of the engine?
PS just wondering is your transcase hooked to the crank pulley or is it in front of the trans and the hole set up is just back assward?
Old May 22, 2011 | 10:55 AM
  #36
alpha/omega
bwahahaha!
Old May 22, 2011 | 11:20 AM
  #37
fatdan460's Avatar
fatdan460
:WINNING:
larry becoming the grammar **** means doom and gloom. when he's schooling you on sentence structure you know the end is nigh. maybe that rapture guy forgot to carry a one or something
Old May 23, 2011 | 01:53 AM
  #38
Roadfind's Avatar
Roadfind
There's just no subsitution for cubbies , but you could inject it and give it a turbo and have the best of both worlds . A 300 I-6 with a spittin hair dryer makes alot of ponies and makes good milage . I'm just sayin,,,,, olllllo
83sd
Dec 2, 2016 11:10 AM
william16339
Oct 25, 2016 08:57 PM
Ole Green 1978
Feb 7, 2012 12:02 PM
mooktank
Jan 3, 2010 02:23 AM
SEDUCED
May 25, 2005 08:33 PM
