Offroad & 4x4
'Power Lok'
Old May 16, 2011 | 04:02 PM
The Freak's Avatar
The Freak
'Power Lok'
This is from a Dana 60 rearend. Will I have any problems using this on my 78 Dana 60 front??
dana 60 power lock For Sale
Old May 19, 2011 | 01:25 AM
hav24wheel's Avatar
hav24wheel
Should work fine and dandy
Old May 23, 2011 | 02:19 AM
Roadfind's Avatar
Roadfind
After running different limited slip diffs and Detriot lockers in Both my Jeep and my 71 F-250 , I settled with Powerlocks in both . The 250 has much better road maners in winter ( the Detriot was trouble on crowned roads ) . The Jeep has never broke anything offroad even pulling a jeep trailer on my backyard trails ( Rubicon and Sierra trek ) . When building the units , set the clutch packs as tight as you can and use good syn oil with the friction modifier . There is better selectable lockers out there , but they cost more ,,,,,, olllllo
Old May 23, 2011 | 03:38 AM
ford390gashog's Avatar
ford390gashog
That is a very nice heavy duty LS units under full power expect 90% lock up which is pretty good for a LS. If you need to rebuild it its really simple and the parts are cheap Dana Spicer Part 22233X - Dana Spicer Power-Loc Clutches also avoid adding to much LS additive to the fluid. In my 76 I run almost none and it gives very nice lockup and no clutch chatter and I inspect the unit and the clutches still look great
Old May 23, 2011 | 09:44 AM
Pkupman82's Avatar
Pkupman82
I am running a Power Lok in the front (full spool in the rear) of my 79 Bronco, and absolutely love it. It's well worn and still hooks both tires most of the time. I recently installed one in the rear (Dana 70) of my 84 F250, it's my plow truck/ tow rig/ work truck. I can't think of a better differential for this application, it performs like a locker but with the smoothness and flexability of a limited slip. It's a great unit I love mine.
Old May 24, 2011 | 12:41 AM
mark a.'s Avatar
mark a.
All Ford front 60's use 35 spline axles, rears are 30 spline so unless there is some outside chance that the rear 60 was converted to 35 or was one of the rare factory 35 spline axles you will have to change the side gears in it.
Old May 24, 2011 | 01:05 AM
fatdan460's Avatar
fatdan460
mark, his link is for a 35 spline powerlock.
p.s. low pinion ford d60 fronts had 30 spline inners :flipoff:
ktm4012
Apr 17, 2016 12:38 PM
Joel Cassell
WTB - Parts & other
Feb 5, 2016 07:53 PM
joe f350
Offroad & 4x4
24
Jan 26, 2011 01:05 PM
mando jake
Offroad & 4x4
May 26, 2010 04:19 PM
Offroad & 4x4
25
Jan 23, 2003 02:04 AM
